Sometimes not going to database
Thread begun 11/04/2010 2:40 pm by wbrooks199805 | Last modified 11/30/2010 10:26 am by Jason Byrnes | 5959 views | 17 replies |
wbrooks199805
I have been having problems with info not posting to the detail page and database. I have attached the insert and registration page along with a screen shot that some people are getting.
Is this a server issue between the database server and the website server or is this something in the code?
where it only happens sometimes, i would guess they are uploading a large file and the max execution time is being excedded, or the post max size is being exceeded.
i would try changing:
// WA Set Server Timeout
if(abs($WA_DFP_UploadStatus["WA_UploadResult1"]["statusCode"]) != 1){
set_time_limit ("300");
set_time_limit (0);
and try changing the post max size in the php.ini file.
wbrooks199805
Parse error
or something like that..I just deleted that completely.
OK, is it working for you now?
wbrooks199805
I am not sure
Its not always populating to the details page from what the client is saying but it is going to the database. But the image some times does not upload which is in the other thread. I think it is interrelated.
OK, lets get the image issue solved first before looking into this one.
wbrooks199805
internet explorer
Okay the blue screen is only in Internet explorer. Why is not posting in IE?
I rebuilt the page to be sure and its saying "no record found" on the godaddy server.
But on my remote server on IE, It works fine. I am using an older php then on godaddy. Godaddy has php5. Also, I am using 2.07 dataassist but it doesn't look the same as what's on your website. I tried both php4 and 5 and its not working.."no record found"
the blue screen? I'm not sure what you mean by this.
is the record being inserted to the database?
Is the image uploading successfully?
We need to fix that problem before tackling this one.
wbrooks199805
Please read
The upload image is NOT related to this. Its a totally different issue.
Internet Explorer is showing "No record found" on the details page. Details are going to database (except sometimes the image is not) HOWEVER, Safari, Firefox and Chrome never show "no record found".
I _did_ read your message, but found it it very confusing to follow the question being asked. I have no idea what you mean by the "Blue Screen", please explain what you mean by the blue screen.
Looking at the insert page attached to the first message, perhaps try changing the trigger for the insert record behavior to use the same any form post as the email behavior.
if that does not work, try changing the following line:
if ($GoToPage!="")     {
    header("Location: ".$GoToPage);
to;
    session_commit();
