Thumbnail image
Thread begun 11/04/2010 7:50 am by ecologictech417149 | Last modified 12/01/2010 8:50 am by Jason Byrnes | 5963 views | 15 replies |
ecologictech417149
Thumbnail image
I would like to add a thumbnail image to the shopping cart for each item. When you click on the thumbnail option in the add to cart menu I dont see where you would set the link up? Please help.
Thank you
in the add to cart button, you specify the file name that should be used for the thumbnail.
In eCart 5, When you add the cart display manager, select the thumbnail column and select the Display As Image option. then select the image folder, this is the folder that will hold the product thumbnail images.
ecologictech417149
if i have already set up the display manager and it has already created all of the checkout pages can I just go in and modify or do I need t delete all of those pages and re create it from the beginning?
yes, you can add an image tag to the cart display. click on the folder icon next to source and set it to dynamic bindings, the select the Image cart column.
you will need to edit the source to prepend the folder to the cart binding, for example:
<img src="images/<?php echo $WA_Store_Cart->DisplayInfo("Thumb"); ?>" alt="" />
ecologictech417149
I opened the e cart object and looked in the columns sections at the thumbnail and I do not see where you edit it as display as please help...
the display as option is only available in eCart 5.
It is available in the eCart Display manager, not the eCart object.
ecologictech417149
I have e cart 5... How do I get to he display manager?
Insert -> Webassist -> eCart -> Display Manager
ecologictech417149
ok ive already went through that set up process once....if i do that again will it just override what ive done or can i edit the old one.
no, you cannot edit a display that is already created.
you will need to edit the code to manually add the image tag:
<img src="images/<?php echo $CartName->DisplayInfo("Thumb"); ?>" alt="" />
