issues with modifying my template
Thread begun 11/03/2010 9:08 pm by ari416039 | Last modified 11/08/2010 10:04 am by Jason Byrnes | 2602 views | 5 replies |
ari416039
I have created a webapge with site sculptor
All is well, but i now want ot change my color choices, i try and go to
web assist - preset manager- on the product tab i select site sculptor then site types.
i can see my site name appear on this list,
when i select my site name and done, nothing happens.
Am i doing something wrong here
Thank you
The colors cannot be changed by editing the site preset.
you will need to edit the CSS for the site to edit the colors used in the site.
ari416039
Thank you for the answer, Sorry mabye i did not explain my self correctly.
I thought the idea of saving a site as a preset was to enable me to add a page or make a modification by choosing a preset color scheme withought the need to recreate an entire site.
Initially when i created my site, i added for example 10 pages and now i want to add a new page and modify my color scheme,
i thought i needed to go back to the site manager, select my preset that i saved and then simply select a different color scheme or add another page or delete a page, was i wrong ?
thank you
The color scheame is built into the preset.
you would need to recreate the preset using the desired color scheme.
ari416039
So that will mean I Also need to recreate my custom size menu bar settings again
I specifically had to adjust my menu bar properties to make all items fit into one line
Either my initial understanding was not right or I see this as a flaw
you're initial understanding of the preset was not correct.
when you save a preset, it contains all of the settings you have applied, including color, widths and heights.
