How to add image and button form elements
Thread begun 11/03/2010 6:34 am by rvoss371864 | Last modified 11/03/2010 8:21 am by Jason Byrnes | 1427 views | 1 replies |
rvoss371864
How can I add an image (type=image) and/or button (type=button or type=reset) form element to a form. It's missing in the list of available trypes when I add a new field. I'm using DW CS5.
Roland
the form will only be created with one button, the submit button.
By default, it will use type="submit"
to convert the submit button to an image, click on the edit css button, from the main select list, select buttons, then choose an image for the button.
you can add a reset button to the form after it is created by going to Insert -> Form -> Button, then changing the action to Reset in the property inspector.
