Convert boolean 1 from database to "yes" on page
Thread begun 11/02/2010 4:04 pm by htm2112 | Last modified 11/08/2010 10:25 am by Dani Chankhour | 2773 views | 3 replies |
htm2112
I am wondering how to convert boolean values retrieved from my database into "yes" and "no" on my page. I have a results page which lists elements of a property. In the database, I have properties that have variables with a 1 for "yes" or a 0 for "no". How can I convert that so I would have: "AC: Yes. Pool: No." etc? In this example, ItemAC=1 and ItemPool=0.
For my update page, these have checkboxes which work fine, but on my results page I want yes/no, because the user is going to view a result, and not be given the chance to update it (which is what a checkbox suggests). Any ideas?
Dani Chankhour
You would have to write conditional statement, here is an example:
if($ItemAC == 1) echo "Yes";
else echo "No"
You will need to replace $ItemAC with your column value.
htm2112
Thanks so much! This worked perfectly! My exact code was <div class="WADADetailsSubText"><span>Air Conditioning:&nbsp;&nbsp;</span><?php if($row_WADAitems['ItemAC'] == 1) echo "Yes"; else echo "No" ?></div>
Dani Chankhour
I'm glad i was able to assist.
