Client VAlidation
Thread begun 11/02/2010 2:22 pm by nickj | Last modified 11/16/2010 7:25 am by Jason Byrnes | 2854 views | 4 replies |
nickj
Client VAlidation
I'm having a problem validating radio button on a custom form using the new client validation behavior.
the field is called gender. When applying the validation do I put it on gender,gender(0) or gender(1)?
onsubmit="WAValidateRQ(document.WADAUpdateForm.pname,'Title - Entry is required',document.WADAUpdateForm.pname,0,true,'select');WAValidateRQ(document.WADAUpdateForm.fname,'First name - Entry is required',document.WADAUpdateForm.fname,0,true,'text');WAValidateRQ(document.WADAUpdateForm.lname,'Last name - Entry is required',document.WADAUpdateForm.lname,0,true,'text');WAValidateRQ(document.WADAUpdateForm.address1,'Address - Entry is required',document.WADAUpdateForm.address1,0,true,'text');WAValidateRQ(document.WADAUpdateForm.city,'City - Entry is required',document.WADAUpdateForm.city,0,true,'text');WAValidateRQ(document.WADAUpdateForm.state,'State/Province - Entry is required',document.WADAUpdateForm.state,0,true,'text');WAValidateRQ(document.WADAUpdateForm.zip,'Zip/Postal code - Entry is required',document.WADAUpdateForm.zip,0,true,'text');WAValidateRQ(document.WADAUpdateForm.country,'Country - Entry is required',document.WADAUpdateForm.country,0,true,'text');WAValidateRQ(document.WADAUpdateForm.date_of_birth,'Date of Birth - Entry is required',document.WADAUpdateForm.date_of_birth,0,true,'text');WAValidateRQ(document.WADAUpdateForm.gender[0],'Gender - Entry is required',false,0,true,'radio');WAValidateRQ(document.WADAUpdateForm.signature,'Attest (last)- Entry is required',document.WADAUpdateForm.signature,0,true,'checkbox');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),false);return document.MM_returnValue"
you should have the option for gender[], gender[0] and gender[1]
you should select the empty one gender[]
nickj
In this form the validation fails on either choice.
<form method="post" name="WAATKRegistrationForm" id="WAATKRegistrationForm" onSubmit="WAValidateRQ(document.WAATKRegistrationForm.first_usr,'First Name - Entry is required',document.WAATKRegistrationForm.first_usr,0,false,'text');WAValidateRQ(document.WAATKRegistrationForm.last_usr,'Last name - Entry is required',document.WAATKRegistrationForm.last_usr,0,false,'text');WAValidateRQ(document.WAATKRegistrationForm.email_usr,'E-mail/ Username - Entry is required',document.WAATKRegistrationForm.email_usr,0,false,'text');WAValidateEM(document.getElementById('WAATKRegistrationForm').email_usr,document.getElementById('WAATKRegistrationForm').email_usr.value,' Invalid email address',document.getElementById('WAATKRegistrationForm').email_usr,0,true);WAValidateRQ(document.WAATKRegistrationForm.password_usr,'Password - Entry is required',document.WAATKRegistrationForm.password_usr,0,false,'password');WAValidateRQ(document.WAATKRegistrationForm.terms_usr,'Agreement with the Terms & Conditions - Entry is required',document.WAATKRegistrationForm.terms_usr,0,true,'checkbox');WAValidateRQ(document.WAATKRegistrationForm.memb_typ_usr,'Membership Level - Entry is required',false,0,true,'radiogroup');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,document.getElementById('false'),false);return document.MM_returnValue">
<h3><span class="orange">On step 1.)</span> Individual Registration</h3>
<table border="0" cellpadding="0" cellspacing="0" class="WAATKDataTable">
<tr>
<th colspan="2">First<span class="Required">*</span>
<input type="text" class="WAATKTextField" name="first_usr" id="first_usr" value="" size="12" />
Middle
<input type="text" class="WAATKTextField" name="middle_usr" id="middle_usr" value="" size="3" />
Last<span class="Required">*</span> <input type="text" class="WAATKTextField" name="last_usr" id="last_usr" value="" size="12" /> </th>
</tr>
<tr>
<th valign="top">E-mail<span class="Required">*</span></th>
<td><p><span class="Required">
<?php if ($totalRows_rsUsed > 0) { // Show if recordset not empty ?>
The email address you entered in use. <br>
Please use a different email address
<?php } // Show if recordset not empty ?>
</span></p>
<p>
<input type="text" class="WAATKTextField" name="email_usr" id="email_usr" value="" size="32" />
</p></td>
</tr>
<tr>
<th>Password<span class="Required">*</span></th>
<td><input name="password_usr" type="password" class="WAATKTextField" id="password_usr" value="" size="10" ></td>
</tr>
<tr>
<th valign="top">Membership type<span class="Required">*</span></th>
<td><input type="radio" name="memb_typ_usr" id="memb_typ_usr" value="1" />
<strong>Level IM-1: $12</strong> <br>
<input type="radio" name="memb_typ_usr" id="memb_typ_usr" value="2" />
<strong>Level IM-2: $16</strong></td>
</tr>
<tr>
<th>Benificiary<span class="Required">*</span></th>
<td><label for="benifitCode_usr"></label>
<select name="benifitCode_usr" id="benifitCode_usr">
<option value="">Select One</option>
do {
<option value="<?php echo $row_rsNon_profit['id_usr']?>"><?php echo $row_rsNon_profit['company_usr']?></option>
} while ($row_rsNon_profit = mysql_fetch_assoc($rsNon_profit));
$rows = mysql_num_rows($rsNon_profit);
if($rows > 0) {
mysql_data_seek($rsNon_profit, 0);
$row_rsNon_profit = mysql_fetch_assoc($rsNon_profit);
</select></td>
</tr>
<tr>
<th>Privacy</th>
<td><input type="checkbox" name="no_contact_usr" id="no_contact_usr" value="1" />
Please do not email me with feature updates.</td>
</tr>
<tr>
<th valign="top">Terms<span class="Required">*</span></th>
<td>Important! Please<a href="#" onClick="MM_openBrWindow('../library/terms_conditions.php','','scrollbars=yes,resizable=yes,width=500,height=500')"> click this link and read the Terms and Conditions</a><br>
<input type="checkbox" name="terms_usr" id="terms_usr" value="1" />
I agree to the terms and conditions</td>
</tr>
<tr>
<th><input name="MM_insert" type="hidden" id="MM_insert" value="MM_insert">
<input type="hidden" name="cdate_usr" id="cdate_usr" value="<?php echo date("Y-m-d H:i:s"); ?>" >
<input type="hidden" name="active_date_usr" id="active_date_usr" value="0" />
<input name="access_usr" type="hidden" id="access_usr" value="1"></th>
<td><span class="WAATKButtonRow">
<input type="Submit" name="Register" id="Register" value="Register">
</span></td>
</tr>
</table>
</form>
nickj
Ment to say it's the "'Membership Level - Entry is required'" field
can you post a copy of the page so i can have the entire code to work with, or post a link where i can the issue in the browser.
