Unknown column 'item' in 'field list'
Thread begun 11/02/2010 1:21 pm by willo009412397 | Last modified 11/04/2010 6:30 am by Jason Byrnes | 3595 views | 7 replies |
willo009412397
Hi
I have created all the pages using dataassist wizard, im using xampp as my localhost.
When i upload the pages the only page that shows is `search page` all the others display
`Unknown column 'item' in 'field list' anyone know what this problem is?
can you send a copy of your pages so I can examine the code.
willo009412397
Hi
Thanks for your help.
the zip you sent only contains one file:
Shortcut to htdocs.lnk
can you resend the php files please.
willo009412397
Sorry Jason my mistake, i have now sent the PHP Pages. I have 2 sites im starting too put together, however im getting this error with both. Thanks for your help.
the problem is caused by using spaces in your column name like:
item name
you should not use spaces in your column names. I suggest using the "Camel Case" naming convention:
itemName
or:
itemDescription
willo009412397
Working great, thanks so much Jason
you're welcome.
