Redirect to Detail after Insert - Works Locally, Not Remotely
Thread begun 11/02/2010 10:52 am by eaefaw380137 | Last modified 11/03/2010 6:57 am by Jason Byrnes | 5098 views | 18 replies |
eaefaw380137
Here I am again. Floundering around as usual and looking for help. It really shows how much I have to learn.
My problem will probably have a simple answer for support but to me it is baffling.
MY PROBLEM
Locally, when I insert a New Product, everything writes to the database correctly, and I am redirected to my details.php page with the newly inserted item results showing.
Remotely, after I insert a New Product, everything writes to the database correctly, but the details.php shows "No Records". I would like it to show my newly inserted record as it does Locally.
My Update behaviors work correctly both locally and Remotely. I feel pretty certain that it has something to do with Sessions. That is my biggest challenge area. I can normally work out the rest.
Any help is appreciated. As always, you guys rock!
the new record id is stored in a session variable, most likely your site has an issue with session management.
use the session test file from the following thread to make sure that session s are working correctly:
showpost.php?p=23826&postcount=2
eaefaw380137
Passed Session Test
Jason,
Thanks for the quick response. You must stay busy from the start of your day till you finally get to leave. I see all the Forum posts, and all of your responses. You are truly dedicated and we appreciate it.
TEST RESULTS = POSITIVE
I tested the Session Management and everything tested correctly. Got NULL, then Test, then Test again.
In case you were going to ask for my pages next, I have attached the items_insert.php and items_details.php (in .txt format).
Thank you so much!
add the following code at line 1 of both pages to turn on error reporting:
if(!session_id()) session_start();
error_reporting(E_ALL);
post back any errors that are displayed
eaefaw380137
No surprise that there was an error
Warning: Cannot modify header information - headers already sent by (output started at C:\hshome\eaefaw\dcd.websmithinteractive.com\admin\items_insert.php:6) in C:\hshome\eaefaw\dcd.websmithinteractive.com\admin\items_insert.php on line 175
eaefaw380137
I tried all I could but have no idea how to correct the error
Warning: Cannot modify header information - headers already sent by (output started at C:\hshome\eaefaw\dcd.websmithinteractive.com\admin \items_insert.php:6) in C:\hshome\eaefaw\dcd.websmithinteractive.com\admin \items_insert.php on line 175
Any ideas are welcome!
please send a copy of your page in a zip archive so I can examine the code.
eaefaw380137
Thanks Jason.
I have attached the files per your request. I really appreciate your efforts.
the error is a result of an extra space at the end of line 5:
remove that blank space at the end of the line to correct the error.
eaefaw380137
Jason,
Thanks for your patience but I am a bit lost. **Surprise huh?**
Remove space from Line 5 of the items_insert.php page or items_details.php page?
Sorry for being a pain but attached are screen shots from my code view of Dreamweaver that shows line 5 of both pages. (I removed the Session Error code you sent earlier) My line numbers doent seem to correspond with your instructions.
Thanks a million.
