Problem with my own Formbuilder Designs in Css Form Builder 2
Thread begun 11/02/2010 4:17 am by Rune Brynestad | Last modified 4/20/2011 11:40 pm by Rune Brynestad | 3202 views | 4 replies |
Rune Brynestad
I have created a few Form Builder Designs in Css Form Builder 1. When I try to use them in Css Form Builder 2 I get some errors.
When I try to Choose my own design in the "Add Form" window I get the Javascript Error in the Fb-1.jpg attachment
When I try to add and edit form fields in the "Edit Group Contents" window I get the Dreamweaver error in the Fb-2.jpg attachment.
I can still use Css Form Builder 2 to construct forms, but I need to click away the error messages all the time, which is a bit annoying. The only limitation is that I can't see my form in the preview window.
I have started over with a new configuration folder and deleted the winfile cache, so there should not be any conflict with other extensions or products.
I have attached one of my Preset Form Builder Designs so you can see if you are able to reproduce the problem.
Thanks in advice
Regards
Rune
Rune Brynestad
Same problem again with the CSS Form Builder 2.0.1 (HTML Editor Compatibility Release
This was solved by Dani Chankhour in Technical Support Ticket # 121144 by replacing the current shared.js file which is located under the Dreamweaver Configuration/Shared/WebAssist/FormBuilder folder with the file attached in the support ticket.
No I have the same problem again because I have upgaded to HTML Editor 3, and need to use the CSS Form Builder 2.0.1 HTML Editor Compatibility Release. The shared.js that ships with the latest version don't include a fix for my problem. I have tryed to repleced the current shared.js with the file attached in the support ticket, but it does not work. I get an error message that tells me that there is a compatibility isue with HTML Editor 3.
Please look at it. I believe you already have the files you need to reproduce the error in this thread and in Technical Support Ticket # 121144.
Thanks.
Regards
Rune
Dani Chankhour
You are correct, it looks like the fix did not make it to this build, i will ensure that the fix will be included in the our next dot release of FormBuilder.
Meanwhile, i have attached an updated shared.js file that have the fix.
Please follow the same instruction as before.
let me know if you have any other questions.
Rune Brynestad
Its working now.
Thanks again for helping me.
Regards
Rune
