CSS Form Builder 200 -- causing a lot of issues
Thread begun 11/01/2010 11:24 pm by michaelf0199272 | Last modified 11/05/2010 9:17 am by Jason Byrnes | 3476 views | 5 replies |
michaelf0199272
CSS Form Builder 200 is causing a lot of problems for me in both CS4 and CS5 even after I uninstalled it.
Please review the pictures provided in the attachments.
Delete the Dreamweaver Cache File from the users configuration folder:
jan373478
Form Builder 200
Same here. I installed Form Builder 200 successfully. Closed out Extension Manager and opened Dreamweaver CS5. I was told that I needed to delete iRite & Universal email and then reinstall Form Builder. It took seemingly forever for Extension manager to uninstall them. When I tried to reinstall Form Builder, Extension Manager hung.
So I deleted the cache file and tried again with the same results: Exchange hung.
This is my second round of doing this. I'm really frustrated as I've never had this much problem with ANY extension except WebAssist's extensions.
I've updated Dreamweaver CS5 on Mac to latest version (11.03). All software is up to date.
To fix the error that you are getting with Form Builder, please try deleting your configuration folder. Once your configuration folder is delete, launch the extension manager and remove all the extensions, and then install only Form Builder, and then launch DW.
Let me know if you are still having the issue after following the above steps.
Thanks.
GadgetGrannie
CSS form
It appears that everything is working now. Thank you for your help.
OK, glad to hear it is working.
