Show All Results Button
Thread begun 11/01/2010 9:56 am by eaefaw380137 | Last modified 11/01/2010 12:04 pm by Jason Byrnes | 3585 views | 7 replies |
eaefaw380137
Before you send me off to all of the other posts within the forum for this topic, I must let you know that I have researched (and tried unsuccessfully) to implement most of these solutions.
I believe that my problem results from the order in which I created my files. Below are the steps that I used.
1.Used Data Assist Wizard to create all files (except email_search.php and email_insert.php) for data that is stored in a MySQL database of emails that are entered into the contact form. The data collection works as expected.
2. I then decided to add search capabilities and used Data Assist Search Wizard. Everything is working as expected all the way from search, results, update, edit, delete functionality. Perfect!
MY PROBLEM: I cannot figure out how to just "Show All" records. The only time it works is when I first navigate to the email_results.php page prior to entering any search criteria. After that, navigating to email_results.php page (either via link or manually) returns the previous search results.
I tried the following Solutions:
1. I am sure it has something to do with the session variables on the email_results.php page and I saw on one post that this could be removed but then the pagination option would be lost. I do not want that.
2. I also saw the option for changing the default WHERE Clause to 0=0 in the Data Assist Search Behavior of the email_results.php page but that did not work.
3. There was also a solution for adding a link on the email_results.php page like this
<a href="email_Results.php?Search_x=0" target="_top">Show All</a> but that did not work. I presume it is because my trigger in the Data Assist Search Behavior looks like this
isset($_POST["WADbSearch2"])) && ($_POST["WADbSearch2"] I even tried replacing Search_x=0 to WADBSearch2=0 in the link above.
I am hoping to find a simple solution without having to recreate all of my pages as I have all of the other functionality of the pages working correctly.
Thanks in advance for your help.
please send a copy of your page so i can find the right solution for you.
eaefaw380137
Show All Results Button - Files Attached
Jason,
As always thanks for your timely response. I have attached the search and results pages in .txt format for your review. Let me know if you need them in another format.
ok, on the results page, create the following link:
<a href="email_Results.php?show=all">Show All</a>
then add this code at line 1:
if(!session_id()) session_start();
if(isset(
$_GET['show']) && $_GET['show'] == "all") {
    unset(
$_SESSION["WADbSearch2_email_Results"]);
eaefaw380137
Jason My Man!!!!
Again you save the day!!! That worked perfectly.
If it is easy enough to explain, why was I encountering that issue? Was it the way/order I created my pages? I presume so, since there was a different trigger in my WA Search Behavior. I would like to know so that I can avoid this issue in the future.
Thanks again.
No, it's not the order the pages where created.
for pagination to work properly, the search criteria are stored in a session. For this page, the session is:
the code i gave you just uses a querystring var to trigger unsetting that session:
if(isset($_GET['show']) && $_GET['show'] == "all") {
unset($_SESSION["WADbSearch2_email_Results"]);
eaefaw380137
Got it. I will be saving that code to my Snippely Air Application. I am sure it will come in handy down the road. Thanks a million!
the only thing you will need to change is the name of the ssession to unset.
look for this code on the results page to determine the session name:
//save the query in a session variable
  if (1 == 1) {
    $_SESSION["WADbSearch2_email_Results"]=$WADbSearch2->whereClause;
so you can find what tot change it to.
