One to many query
Thread begun 10/31/2010 6:20 am by twitchr377598 | Last modified 11/03/2010 6:52 am by Jason Byrnes | 5014 views | 11 replies |
twitchr377598
One to many query
Well my friends, I have been pulling my hair out for over a day and I finally had to admit I needed help. I haven't had much experience with one to many relationships and this particular query is driving me batty and I don't think any of my Webassist extensions can help me with this one...haha
Ok, I am generating some checkboxes via a table like so:
<?php do { ?>
              <input <?php if (!(strcmp($row_venues_RS['userID'],116))) {echo "checked=\"checked\"";} ?> name="venueID_<?php echo $row_venues_RS['venueID']; ?>" id="venueID_<?php echo $row_venues_RS['venueID']; ?>" type="checkbox" value="<?php echo $row_venues_RS['venueID']; ?>" />
              <?php echo $row_venues_RS['venueName']." ".$row_venues_RS['venueID']; ?><br />
<?php } while ($row_venues_RS mysql_fetch_assoc($venues_RS)); ?>
This query almost works. The proper venue (or venues) is checked, but as you can guess I get duplicates:
SELECT venues.venueID, venues.venueName, venue_user_access.userID FROM
  venues INNER JOIN venue_user_access USING (venueID) WHERE venues.venueMasterID = %s AND venueStatus = 1 ORDER BY venueName ASC
These checkboxes are on an update record page so my goal is to show all venues tied to the venueMasterID (the value is stored in a sessions variable) from the venues table and check the ones that userID 116 has access. The access table essentially has a venueID and userID field. Is this possible with a single query? I haven't written a lot of complex ones therefore I may be missing some function to make this easier.
I have read up on and tried DISTINCT and GROUP BY, but never got the results I desired. So anyway, I am posting on the chance someone has an idea.
Thanks in advance,
Twitch
you need to add a GROUP BY clause:
venues INNER JOIN venue_user_access USING (venueID) WHERE venues.venueMasterID = %s AND venueStatus = 1 ORDER BY venueName ASC GROUP BY venues.venueID
twitchr377598
Jason,
Can't tell you how much I appreciate the reply. Pulling my hair out for a couple of days. I had tried GROUP BY before and got an error. When I copied and pasted your query I got a similar error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'GROUP BY venues.venueID' at line 2
This happens whenever I try to add GROUP BY. Any ideas?
Thanks again
did you try moving the group by before the order by:
GROUP BY venues.venueID ORDER BY venueName ASC
twitchr377598
Again, thanks for the quick response. I think putting it before the order by was the only place I hadn't tried. Probably just missed it in my frustration...haha The error is gone, but now I need to figure out how to check any venue that userID 116 has access to. That only works when all the duplicates are showing up. I know why, but not sure how to fix it.
Again, thanks for the much needed help. Purchasing webassist extensions has been the best thing I've done since starting web design.
looking at the code, the userID is being used to control the venue:
not the venue iD, it seams to me that the venue ID should be used here, not the users ID.
twitchr377598
I'm sure my explanations are confusing...maybe a look at my structure will help. Maybe what I'm asking can't be done or my db structure is incorrect.
venue_user_access table:
userID | venueID
116 | 65
116 | 66
114 | 65
etc | etc
venues table:
venueID | venueMasterID | venueName | other columns with venue info
65 | 113 | My Club | blah blah blah etc
66 | 113 | Club 2 | blah blah
The page I'm doing this query on is a page to update the user's (in my test case userID 116) access to clubs owned by venueMasterID 113. On the insert page I used one of the extensions (can't remember which one) to repeat and insert some checkboxes that contained the clubs owned by venueMasterID 113. Now I would like to generate the checkboxes on the update user page based on clubs owned by venueMasterID 113 and have the ones that userID 116 has access to show up as checked and the other ones unchecked.
Seems like a simple doable thing, but it's been a hair puller haha.
Again, the help is certainly appreciated.
-Twitch
my point is that the venue id is being used for the value:
so it should also be used as the control for whether the checkbox is checked or not.
twitchr377598
The reason I use userID to check or uncheck is because I only want the ones that userID 116 has access to to be checked when rendered. It works if I simply let it show the duplicate venues with a simple INNER JOIN query because it's pulling all the venues that 113 owns and checking the ones that 116 has access to. The problem is the duplicates showing.
For instance, instead of seeing a list of checkboxes with Club 1 and Club 3 checked:
[x] Club 1
[ ] Club 2
[x] Club 3
where userID 116 has access to club 1 and 3 I get:
[ ] Club 1
[ ] Club 1
[x] Club 1
[ ] Club 2
[ ] Club 2
[ ] Club 2
[ ] Club 3
[ ] Club 3
[x] Club 3
above is basically showing all the records (and users) that have access to clubs that are owned by 113 and checking the proper Clubs that userID has access to. My goal is the weed out the duplicates. I change the query to do that, but then it doesn't check them.
Maybe I just need to figure out a different way to structure my one to many relationship, but everything I've read on it seems to point to this way. I think the key is the proper query.
Sorry if I am confusing you Jason...haha
yes, the key is the proper query.
you need one query to return all venues, and one query to return only the venues associated to the user, then use the venue id from the recordset that is being filtered to drive which checkboxes are selected.
