Alignment of image problem
Thread begun 10/30/2010 3:22 am by Meic Delwedd | Last modified 11/01/2010 11:44 am by Jason Byrnes | 4677 views | 7 replies |
Meic Delwedd
I've created this page for a client keith-bowen.php
My problem is that I've tested it on 4 PCs, Google Chrome, IE 8 and Firefox, and the main (large) image is centrally aligned (as it should be) on all of my equipment. However my client has a Widescreen Monitor/PC 1600 x 900, using Mozilla Firefox, is seeing the main image right aligned. Is this a cache issue or is there a problem with my page - I'd really appreciate any help please? THANK YOU
neilo
Am viewing in Firefox 0n 1900 x 1200 and images are perfectly centred.
Meic Delwedd
proanny 1982
THANK YOU Neil - It's probably a cache problem on my client's PC then?
neilo
That's certainly possible, and worth having your client check it out.
Meic Delwedd
Thank you
Thank you Neil - This has now worked!
Meic Delwedd
Still not working
Although our client can see the large image centre aligned in the sample gallery page, the images are centre aligned:-
index.php?gallery=6&theme=light
However when he examines our page using the same gallery style (the only element we've changed in the stylesheet is the background colour to match with his website). Unfortunately he has again told us that "There is an outline box centred but the image is still over to the right, although a bit less so than before."
keith-bowen.php
As we have not changed anything else, what could be making the large image right aligned, could the alignment be affected by the size of the uploaded image?
Meic Delwedd
Workaround!
We've now created a workaround by including the php in a table - This has resolved issue...
ok, glad to hear it is working now.
