In category display products_results.php becomes root during Next and Last from Side
Thread begun 10/29/2010 5:13 pm by jefflamrouex | Last modified 11/01/2010 3:42 pm by jefflamrouex | 9876 views | 10 replies |
jefflamrouex
Greetings -
I need some help on a small problem with the site dacfeedstore.com
Show all products links work fine, and the top links to the product categories work fine, but when using the sidemenu, and the number of products exceeds one page (presenting a 'Next' and 'Last' link) clicking on the 'Next' links tries to jump to, for example using 'High Performance Horses', "http://products_results.php/?pageNum_WADAProducts=1&totalRows_WADAProducts=10&Search=1&ProductCategoryID[]=8"
instead of
"http://dacfeedstore.com/products_results.php?pageNum_WADAProducts=1&totalRows_WADAProducts=10&Search=1&ProductCategoryID[]=8
Thanks in advance for the help. We're really liking PS4
-Jeff Lamrouex-
see this post for files to fix the issue:
showpost.php?p=78449&postcount=16
jefflamrouex
Same problem remains after applying fix
Thanks for the the reply and files, Jason, but the same problem remains unscathed.
Other thoughts?
Best Regards,
-Jeff-
I am testing your site at the link you provided in the initial post and it is working for me. Perhaps, you need to clear your browsers cache.
jefflamrouex
Problem still exists after clearing, etc.
Hi Jason,
First, thanks for the reply.
That's what I thought it might be also, so I cleared all caches with the same results. I also downloaded and ran fresh browsers on this and another OS, and tried the same thing on an alien machine. Same results. Not to be redundant, but here's the specific formula to see what I mean:
Navigate to the Home page of dacfeedstore.com
Click the Products menu at the top to display all products
Click the side menu "High-Performance Horses"
Click either 'Next' or 'Last' to the right of breadcrumbs 'Products 1 to 9 of 10'
Error (link tries to go to products_results.... instead of products_results....
Also, any menu selections made from the top 'Products' menu only, are fine. All the submenus, including the one listed above work just fine.
But, if you click at any time on one of the side menus that exceed one screen, the link is wrong.
Thanks again,
-Jeff-
did you download the 4.01 power store update that is available from the download center?
jefflamrouex
2.02 ?? Using PowerStore 4.0.1
Jason -
We're using PS 4.0.1 for this site.
Thanks,
-Jeff-
ghaa, getting products and their versions mixed up.
Those files i linked to should fix the problem.
try uploading them once again, this time though, add today's date after the body tag first so we can verify that the upload is going up correctly.
jefflamrouex
Date added; appearing near breadcrumbs; same result
Hi Jason -
I added the date as requested to verify uploaded files.
No change from this side.
Thanks again for looking at this for me.
-Jeff-
Dani Chankhour
the fix seems to be in the results.php under webassist/plugins/catalog/ folder and changing this line of code:
$currentPage = dirname($_SERVER['PHP_SELF']) . '/' . $currentPage;
to
$currentPage = dirname($_SERVER['PHP_SELF']) . $currentPage;
