Stuff Not Working
Thread begun 10/29/2010 11:25 am by rob294118 | Last modified 10/29/2010 3:25 pm by neilo | 2276 views | 5 replies |
rob294118
Stuff Not Working
What is the point of setting values in the CSS Form Builder 2 form when I have to also go into the Universal Email server behaviors to get things to work?
Where do I create the email the actual email? I'm only given a Preview of it. Do I really have to create it in the blank template that comes up?
What is the Hidden field for and how do I get rid of it?
Contact Form Submission
Form Submitted: 10-29-2010 | 2:16 PM EDT
Full Name: rob
Email Address: rob@pyxels.com
Comments: testing
Hidden Field:
rob294118
I also have the Full Name field set and it does not show up in the Email From field.
neilo
Hi Rob,
You will get this if you leave the tick-box checked, selecting the default template. You can either modify that template, make a new template of your own, or start from a blank email, -which is my preferred method.
From a blank email, I can create my message and bind the form values to it wherever I want.
Have a look here to see what works for me. (Excuse the abysmally slow typing).
rob294118
Thanks a lot.
rob294118
I'm still not getting the From: field filled in my email. I have this in my waue_contact_1.php file:
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "".((isset($_POST["Full_Name"]))?$_POST["Full_Name"]:"") ."";
$MailSubject = "Contact Form Submission";
$_SERVER["QUERY_STRING"] = "";
neilo
I'm not sure why that is, other than that I think the 'from' field is usually the field you would bind the sender's email address to. The email would need to have a 'sender'. So in mine, If the email was being sent to me as the site owner, then I would bind the form's email address field to to the 'from' field via the lightening bolt:
$MailFrom = "".((isset($_POST["Email_Address"]))?$_POST["Email_Address"]:"") ."";
I would add the Name binding to the email body.
