Is there any way for SS to generate pages that aren't in one of the menus?
Thread begun 10/29/2010 10:58 am by Lon Winters | Last modified 11/04/2010 9:28 am by saf01 | 3650 views | 6 replies |
Lon WintersBeta Tester
Right now, I just add all the pages I want to the footer just so SS will generate the pages for me, then I re-do the actual foot navigation and content afterwards from the template.
Dani Chankhour
No, Site Sculptor will only create pages that are in the menu. However, after Site Sculptor is created, you can create pages from the Template that is created, since Site Sculptor will create a template.
saf01
Hello. Could you tell us how to create a template cms page that is not in the menu - I forgot to add a page in SS realising afterwards - I have modfied the pages and css, bascially don't wish to start the whole process again of creating the SS site again. Please advise. thx
Dani Chankhour
You will have to upgrade to the full version Of PowerCMS in order to add a cms template.
saf01
Thx Dani. I
Ive added a new page as a cms page without remaking the whole SS site. Its works for me, but may or may not work for you.
I copied one my generated pages (eg aboutus.php as departments.php for example). In Dreamweaver with the departments.php open, I changed all 'About Us' PowerCMS Connections to 'Departments' in the title, meta description and meta keywords. Then I changed all the module positions php code e.g.
<?php echo WA_getCMSContent............ 'About Us' , 'leftmodule'); ?>
changed to
<?php echo WA_getCMSContent............'Departments' , 'leftmodule'); ?>
Then basically running an SQL statement in phpMyAdmin by copying and pasting the page values of an existing content from my site's exported db (pcms2_contents) table back into phyMyAdmin and run it as an SQL statement:
INSERT INTO `pcms2_contents` (`ContentID`, `ContentGroup`, `ContentRefID`, `ContentUserID`, `ContentValue`, `ContentDate`, `ContentPageName`, `ContentPageSetParentID`, `ContentPageSetOrder`, `ParentID`) VALUES
(13, 'Departments', 'meta-title', 0, 'Areas We Cover', '2010-10-31 22:50:48', NULL, NULL, NULL, 1),
(14, 'Departments', 'meta-description', 0, '', '2010-10-31 22:50:48', NULL, NULL, NULL, 1),
(15, 'Departments', 'meta-keywords', 0, '', '2010-10-31 22:50:48', NULL, NULL, NULL, 1),
(16, 'Departments', 'content', 0, '<h1>Page Title Goes Here</h1>title goes here', '2010-10-31 22:50:48', 'departments.php', NULL, NULL, 1),
(17, 'Departments', 'leftmodule', 0, '', '2010-10-31 22:50:48', NULL, NULL, NULL, 1)
I tested the new page, seems to work without any errors.
Please can you tell me are there be any complications doing it this way?
Dani Chankhour
I did a quick test and that seems to work, but i you will have to make sure that you don't have row 13, 14, 15, 16 and 17 in your database. Basically you would want to increment those numbers according to the last row id in your database.
saf01
Thnx Dani. Thats good.
