search for only some criteria
Thread begun 10/29/2010 10:27 am by i.edwards384429 | Last modified 11/01/2010 2:50 pm by Jason Byrnes | 3670 views | 7 replies |
i.edwards384429
Hi
thanks to all the help I now have a working results page with a non exact search.
So I took a backup copy and started testing , realised that although it worke every search field had to be filled in.
So I thought ( I know dangerous) that if i the code below I changed the AND to an OR it would allow a search based on either 1,2,3 or 4 of the criteria.
Wrong!!!
is there a "phrase" for AND/OR
thanks
Ian
it should ignore form fields that are not filled in.
Can you send a copy of the page so I can see the code.
i.edwards384429
files
Hi Jason
I've attached both the search and results pages.The unequal seach works perfectly.
There are 5 search fields.
the fist two, Name and type are a basic text search so that if someone wants to find a boat called "fred" just that boat is listed the same as a search for "catermaman" would just list boats of that type.
The three other fields are:
cost
berths and loa
all three of which now have a variance built in so the cost search is +/- 5000.
If I leave the first two fields blank they seem to be ignored but the last three appear to "required" because unless all three fields have a value no results are shown.
Thanks for the assist and have a good weekend
cheers
Ian
try changing:
$WADbSearch1->addComparison("dt_Price","" . ($_GET['S_dt_Price']  -5000) .  "","AND",">=",1); $WADbSearch1->addComparison("dt_Price","" . ($_GET['S_dt_Price']  +5000) .  "","AND","<=",1);
  $WADbSearch1->addComparison("dt_loa","" . ($_GET['S_dt_loa']  -10) .  "","AND",">=",1); $WADbSearch1->addComparison("dt_loa","" . ($_GET['S_dt_loa']  +10) .  "","AND","<=",1);
  $WADbSearch1->addComparison("dt_berths","" . ($_GET['S_dt_berths']  -2) .  "","AND",">=",1); $WADbSearch1->addComparison("dt_berths","" . ($_GET['S_dt_berths']  +2) .  "","AND","<=",1);
$WADbSearch1->addComparison("dt_Price","" . isset($_GET['S_dt_Price'])?($_GET['S_dt_Price']  -5000):$_GET['S_dt_Price'] .  "","AND",">=",1); $WADbSearch1->addComparison("dt_Price","" . isset($_GET['S_dt_Price'])?($_GET['S_dt_Price']  +5000):$_GET['S_dt_Price'] .  "","AND","<=",1);
  $WADbSearch1->addComparison("dt_loa","" . isset($_GET['S_dt_loa'])?($_GET['S_dt_loa']  -10):$_GET['S_dt_loa'] .  "","AND",">=",1); $WADbSearch1->addComparison("dt_loa","" . isset($_GET['S_dt_loa'])?($_GET['S_dt_loa']  +10):$_GET['S_dt_loa'] .  "","AND","<=",1);
  $WADbSearch1->addComparison("dt_berths","" . isset($_GET['S_dt_berths'])?($_GET['S_dt_berths']  -2):$_GET['S_dt_berths'] .  "","AND",">=",1); $WADbSearch1->addComparison("dt_berths","" . isset($_GET['S_dt_berths'])?($_GET['S_dt_berths']  +2):$_GET['S_dt_berths'] .  "","AND","<=",1);
i.edwards384429
update
Hi Jason
thanks for that, It seems to be a step in the right direction but I get the following when I run some test searches
search on price only I get no results
search on LOA only I get no results
search on berths only I get no results
search on LOA and Berths I get no results
search on price and berths I get no results
search on price and loa I get results
search on price, loa and berths I get results
I'm sure there is some logic there just at the moment I cant see it.
I'll get back on it on monday - busy today getting the house ready for visitng ghouls and ghosties tomorrow;-)
thanks
Ian
ok, maybe try using this code instead:
if(isset($_GET['S_dt_Price']) && $_GET['S_dt_Price'] != "") {
if(isset($_GET['S_dt_loa']) && $_GET['S_dt_loa'] != "") {
if(isset($_GET['dt_berths']) && $_GET['dt_berths'] != "") {
i.edwards384429
update
Hi Jason
thanks for the assist works perfectly, now all I have to do is try to understand the code;-)
cheers
Ian
i put an if statement around each comparison so it would only be added if the corresponding form element where set and not equal to a blank string:
