Multiple Insert Before Page Load
Thread begun 10/29/2010 9:44 am by dan361748 | Last modified 10/29/2010 12:31 pm by Jason Byrnes | 2236 views | 5 replies |
dan361748
Hi - wondering if someone out there could give some guidance. I've been trying to figure this out for a couple of days now.
On my 'checkout-success' page I'm trying to insert multiple records to a table on page load. If I add in a submit button and bind that to the trigger of the multiple insert behavior, the records insert correctly on pressing submit. However if I bind the trigger to 'before page load' (which is what I want) the records don't insert on page load.
Here is my code at the top of the page:
//WA eCart Include
require_once("WA_eCart/eCart1_PHP.php");
<?php require_once('Connections/ourhands1.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
$eCart1->GetContent();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$_SESSION['ticketstemp'] = session_id();
$colname_ticketstemp = "-1";
if (isset($_SESSION['ticketstemp'])) {
$colname_ticketstemp = (get_magic_quotes_gpc()) ? $_SESSION['ticketstemp'] : addslashes($_SESSION['ticketstemp']);
mysql_select_db($database_ourhands1, $ourhands1);
$query_ticketstemp = sprintf("SELECT * FROM tickets_temp WHERE sessionid = %s", GetSQLValueString($colname_ticketstemp, "text"));
$ticketstemp = mysql_query($query_ticketstemp, $ourhands1) or die(mysql_error());
$row_ticketstemp = mysql_fetch_assoc($ticketstemp);
$totalRows_ticketstemp = mysql_num_rows($ticketstemp);
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "-1";
// WA DataAssist Multiple Inserts
if ("" == "") // Trigger
$WA_loopedFields = array("firstname", "lastname", "nameatcamp", "yearsatcamp", "email", "areasatcamp");
$WA_connection = $ourhands1;
$WA_table = "ticketdetails";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "orderid|cartid|firstname|lastname|nameatcamp|yearsatcamp|emailaddress|areasatcamp";
$WA_columnTypesStr = "',none,''|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_insertIfNotBlank = "";
$WA_connectionDB = $database_ourhands1;
$WA_multipleInsertCounter = 0;
while (WA_AB_checkMultiInsertLoopedFieldsExist($WA_loopedFields, $WA_multipleInsertCounter)) {
if ($WA_insertIfNotBlank == "" || WA_AB_checkLoopedFieldsNotBlank(array($WA_insertIfNotBlank), $WA_multipleInsertCounter)) {
$WA_fieldValuesStr = "".((isset($_SESSION["eCart1_OrderID"]))?$_SESSION["eCart1_OrderID"]:"") ."" . "|" . "".$eCart1->DisplayInfo("ID") ."" . "|" . "".WA_AB_getLoopedFieldValue("firstname", $WA_multipleInsertCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("lastname", $WA_multipleInsertCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("nameatcamp", $WA_multipleInsertCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("yearsatcamp", $WA_multipleInsertCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("email", $WA_multipleInsertCounter) ."" . "|" . "".WA_AB_getLoopedFieldValue("areasatcamp", $WA_multipleInsertCounter) ."";
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$WA_multipleInsertCounter++;
if ($WA_redirectURL != "") {
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
$eCart1->ClearCart();
session_regenerate_id();
Many thanks for any help!
the multiple insert behavior is expecting form input that is not available on page load, the form input information is only available when the form on your page submits, you would be able to do this on page load.
dan361748
Thanks Jason
I'm kind of struggling with the sequence on how to do this. Could you give me your advice at a high level?
Here's what I'm trying to do:
I have populated a temporary table with user ticket information (name, email address etc). The key to the table is the user's session id. The user enters this data on a form that comes up directly before the checkout page.
On the checkout_success page the system copies the tickets_temp table records to the ticketdetails table inserting the orderid received on the checkout_success page.
I have most of the above working, but the insert many behaviour won't work unless I put the tickets_temp table data into a repeat selection form. I don't want the user to have to click and submit a form - I just want those records to automatically be inserted on reaching the page. I intend on setting up a delete records behaviour to clear out the tickets_temp table at the end.
Should I use the insert many behaviour or is there another way to do this?
Many thanks - again.
Dan
no, not an automated way to do this, you need to write the php code to loop through the temporary table contents and insert the data into the other table.
This will require hand coding to accomplish, the extensions will not be able to automate this for you.
dan361748
Ok thank you for taking a look.
you're welcome.
