Switching from Large to Small
Thread begun 10/29/2010 8:11 am by nickj | Last modified 10/29/2010 11:36 am by neilo | 2229 views | 5 replies |
nickj
When I first inserted the editor I had it large, all the menus, now I would like it to be minimal and have edited the editor as such, uploaded the page and the custom but the menu remains.
h Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("statement_art", "../../webassist/html_editor/", "600px", "400px", "Custom", "../custom/artist_art_Insert_statement_art1.js", "");
I assume that the file did not update correctly please advise.
Nick
see attached!
neilo
Hi Nick,
It may be that HTMLEditor has created a new (duplicate) directory for its files. The page code you posted shows the HTMLEditor folder as being inside the webassist directory, which is presumably in the root directory of your site.
Was your original HTMLEditor folder in a webassist directory? Do you now have two HTMLEditor directories? This can happen if an instance is originally created inside a folder in the root directory and is subsequently edited, and would also create your exact scenario if you have installed CSSFormBuilder2 since creating the original editor instance.
If you could confirm whether this is/is not the case, it would clear the way for a proper diagnosis.
Cheers
nickj
Yes
There is a second HTLMeditor folder (original), but doesn't have the reference to artist_art_Insert_statement_art1.js can I delete the original or what should I do?
neilo
You have two options,
Either:
You can choose the newly created webassist/html_editor folder to be the one that is used (this would be the best choice if you are likely to be editing the HTMLEditor instance again in the future or adding HTMLEditor to more pages), if you choose this option you would need to upload the whole new webassist/html_editor folder to your remote server, and once your page checks out OK on your live site, you can delete the old HTMLEditor folder.
Or:
Copy the new artist_art_Insert_statement_art1.js into the original HTMLEditor/custom folder, and change the paths on your page that contains the Editor instance back to point to your original HTMLEditor folder. I don't know your site structure, but:
If the page with the Editor instance on it is in the same directory as the original HTMLEditor folder, the paths would be something like:
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("statement_art", "HTMLEditor/", "600px", "400px", "Custom", "../custom/artist_art_Insert_statement_art1.js", "");
If the page was one level deeper than the HTMLEditor folder, the paths would be something like:
$WARichTextEditor_1 = CreateRichTextEditor ("statement_art", "../HTMLEditor/", "600px", "400px", "Custom", "../custom/artist_art_Insert_statement_art1.js", "");
nickj
Great, thank you
Really appreciate the fast response. Ideally I would like to get rid of one of the folders. I guess I could look at timestamps and keep the newest.
neilo
If you have uploaded the newer folder (which I guess would be the webassist/html_editor/ folder) and your page looks and works fine, it would - I think - be best to keep this newer one. That would prevent the same problem happening if ever you need to update the instance or add the Editor to new pages.
Then just rename the old HTMLEditor folder on your live server to anything, and check your page again. If all is still fine, then you can delete the old HTMLEditor (renamed) folder. Just to be safe.
