How do you use the delete option for a field?
Thread begun 10/28/2010 11:07 pm by htm2112 | Last modified 11/09/2010 7:24 am by Jason Byrnes | 2329 views | 3 replies |
htm2112
Hello. I have built an update records page that works well. I can update a thumbnail and various text fields. Problem is, I cannot figure out how to delete something. So, this page if for a property. It has has 14 thumbnails and a text field for the alt tag. Let's say I want to delete thumb #14. How could I do this? I could rename the server file name for thumb 14. Or I could delete the actual file on the server. It would be nice if I could do both. How can I accomplish this? I see that File Manipulation has a delete and rename behavior. I could not get either to work for me. Any ideas? Thanks!
to get this working, for all 14 fields individually, you will need to be careful with triggers being used for the Update record behavior.
Make sure the update record behavior is set to trigger on the Button U[pdate being pressed, or whatever the main submit button is.
Once the update is set to trigger on the specific submit button, you can add additional submit buttons next to each file field to delete that specific file. Set the name each one to be unique like 'delete1" or "delete2" Set the value for each one to use the image column from the database.
then you can add a delete file server behavior for each delete button. Set the trigger to use that specific delete button. make sure the Delete Folder is set to the same folder as the upload behavior. For the delete file, click the lightning bolt icon and select the corresponding delete button.
htm2112
Thank you. I have gotten it to work partially. I get the file deleted off the server, but I also need to delete the file name that is stored in the database. So I have:
$WA_DeleteFileResult1 = false;
if(isset($_POST["deleteImage"])){
$WA_DeleteFileResult1 = WA_FileAssist_DeleteFile("../images/details/", "".((isset($_POST["ItemImage"]))?$_POST["ItemImage"]:"") ."");
But, ItemImage still contains the file name. The file has been successfully deleted from the server. How do I delete the value stored in ItemImage as well? I suspect I need another command to put a NULL value in ItemImage or something to update ItemImage to nothing. Could you help me out with that?
You need to add an update record behavior to update the record in the database and remove the file name.
