Error msg: Warning Can't send cache limiter
Thread begun 10/28/2010 11:02 am by Larry321390 | Last modified 10/29/2010 7:25 am by Larry321390 | 1984 views | 2 replies |
Larry321390
After i moved from test server to porduction I'm getting thie warning when the form is called. Production server is on a different machine the test. I changed the path to the new location.
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/bni/public_html/contactForms102/WA_Globals/WA_Globals.php:22) in /home/bni/public_html/contactForms102/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
Dani Chankhour
The error is generated when you extra spaces outside the php tags. Please look at your WA_Globals.php fiel at line 22 and make sure to remove any extra spaces that are outside the <?php ?> tags.
Larry321390
Thanks.
I removed all th comments and that fix it.
