Error Message
Thread begun 10/28/2010 10:24 am by dmheltzel267059 | Last modified 10/28/2010 1:26 pm by Jason Byrnes | 3395 views | 6 replies |
dmheltzel267059
Error Message
Warning: mkdir() expects at most 2 parameters, 3 given in /home/content/d/m/h/dmheltzel/html/CelebrityRanch/webassist/caching/CachedResize_Image.php on line 229
Ran it the first time, all seemed to work. Now I can't get rid of the above error message.
dmheltzel267059
May have solved?
I'm testing on a live server in which the site right now is a subfolder of the hosting domain. Locally everything seem to work fine, but under the live server subfolder I was receiving the error message. I tested at the root of the hosting domain and all seems to work. Not sure if that is the solution but I'm going with it for now!
Sounds like it may have been a permissions issue with the subfolder it was in.
dmheltzel267059
Well, never mind. I'm getting the error message again. I've tried the folder permissions and set them to 777 - read/write/execute - for all the folders containing the raw image and still see the error. Now, when the image_cache file is dynamically created, it does not default to the same permissions. Could this be the issue?
dmheltzel267059
Refresh causing problems
Every time I try something new, deleting files and renaming, it works the first time. But, when I hit refresh, the error message appears. Why would that be? I've spent too much time trying to figure out what should be simple. May have to punt on this extension.
dmheltzel267059
pailium Universita
If I delete the folders that are dynamically created to hold the thumbnails, I can refresh the browser and they show up. But, if I refresh again after that, I receive this:
Fatal error: Call to undefined function: scandir() in /home/content/d/m/h/dmheltzel/html/webassist/caching/CachedResize_Image.php on line 262
you are reporting this issue in two places, please see my reply to your other thread:
forumqueue.php#thread_79297
