Creating Menu Spacing
Thread begun 10/28/2010 8:29 am by michael271032 | Last modified 10/29/2010 6:38 am by Jason Byrnes | 1927 views | 3 replies |
michael271032
I have created a menu with Menu Writer 2 and I am trying to figure out how to create some spacing between the buttons. Right now they are piled on top of each other with no space and I would like to put about 10 pixels of space between them.
I was able to add some padding and it worked, but it created a new issue. I want the sub menu to stay squared up as it currently is right now with NO padding between the buttons. However when I add the padding between the buttons it shoves the sub menus up as well and they are no longer squared up with the training button. Please see the attached PDF to see what I have done.
If you look you will see all I want to do is add the padding BETWEEN the buttons, BUT leave the sub menu squared up with the training like it is in the picture below.
On the Edit Menu Design screen, set a 5px top margin for the main menu item.
michael271032
Issue Fixed
Thank you, that worked perfectly.
you're welcome.
