PwerCMS2 fresh install wrong path
Thread begun 10/28/2010 7:57 am by admin140217 | Last modified 10/29/2010 6:39 am by Jason Byrnes | 1760 views | 3 replies |
admin140217
I have recently done a fresh install of PowerCMS2 on a clients server but the path seems to be incorrect, see below:
contents_update.php?ContentID=1
For some reason it's pointing to the common folder for the contents_update.php file when it's in the admin folder.
I have looked at all the paths and the point the same way. What's the best way to fix this?
Paths look like this:
<?php require_once( "../../CMS/WA_Globals/WA_Globals.php" ); ?>
<?php require_once('../../CMS/Connections/PowerCMSConnection.php'); ?>
<?php require_once("../../CMS/HTMLEditor/WARichEditorPHP.php"); ?>
<?php require_once( "../../CMS/WA_CMS/WA_CMS.php" ); ?>
<?php require_once("../../CMS/WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once( "../../CMS/WA_SecurityAssist/Helper_PHP.php" ); ?>
The CMS folder is in the root.
Thanks,
look in the wa_settings table of the PowerCMS database, the PCMS Remote Root should be set as:
/CMS/
admin140217
Update
Thanks Jason, I had actually done this before your post but what I have found works best is to unzip the files to a directory of their own, the path stays the way it should and I can FTP the files for install.
Ok, glad to hear it is working.
