Menu Error Message
Thread begun 10/28/2010 7:33 am by mrobben375515 | Last modified 6/28/2011 4:52 am by Nico | 5561 views | 9 replies |
mrobben375515
Menu Error Message
After installing PS3, I'm getting this error message. The link to the homepage is index.php
Warning: main(../Connections/PowerStoreConnection.php) [function.main]: failed to open stream: No such file or directory in /home/content/c/u/t/cutepets/html/checkout/CSSMenuWriter/cssmw_home/menu.php on line 23
Fatal error: main() [function.require]: Failed opening required '../Connections/PowerStoreConnection.php' (include_path='.:/usr/local/lib/php') in /home/content/c/u/t/cutepets/html/checkout/CSSMenuWriter/cssmw_home/menu.php on line
send a copy of the CSSMenuWriter/cssmw_home/menu.php file please.
mrobben375515
Here's the file
try changing:
// MenuWriter connection includes
require_once($WA_dotDotSlash . "Connections/PowerStoreConnection.php");
require_once("../../Connections/PowerStoreConnection.php");
mrobben375515
That didn't work, so I checked the PS3 original files and that's how it comes out of the box. Do you think something is wrong with the tree xml or something else? I'm not a programmer so it's hard to diagnose things, but this line right after where you told me to make the change
if (1 == 0) {
?><?php require_once('../../Connections/PowerStoreConnection.php'); ?><?php } // End MenuWriter ignore connection includes ?>
is what you referenced that the menu.php should be looking to for the power store connection. So what does the if (1 == 0) mean? is that checking something from the tree xml or the database? I've attached the whole folder in case you need to see the tree xml or something. thanks
No, it's something in the tree xml.
on a couple of rare occasions i have seen issues where the common logic of the file structure doesnt quite work as expected.
Usually ,the require path is relative to the file the connection being added to, but in a couple of cases, i have seen where the require path is relative to the page the menu is in instead.
try changing:
require_once("Connections/PowerStoreConnection.php");
mrobben375515
That was it! Thanks for the help
you're welcome.
Nico
Same error
Getting the same error.
Tried to do what you suggest but didn't work.
The menu works when it is accessed directly or included inside a file in the root folder, but doesn't work when it's included in another file, inside a subfolder .
Nico
Problem solved
Hi. Problem solved.
Did change the url inside the file that includes the menu (in the file that is created by the CSS menu writer).
For example I changed this
<?php require_once("CSSMenuWriter/cssmw/menu.php"); ?>
To
<?php require_once("http://www.mydomain.xxx/CSSMenuWriter/cssmw/menu.php"); ?>
