New to framework builder
Thread begun 10/27/2010 8:45 pm by JBWebWorks | Last modified 11/08/2010 9:31 am by Ray Borduin | 3849 views | 7 replies |
JBWebWorks
I just purchased framework builder and need help on a project (not sure if framework builder will do what i want?)
I have a javascript countdown timer clock on page 'clock.php'
I have a submit button on page 'bidding.php'
I want to plugin the clock.php function on the bidding.php page and have the submit button refresh the clock.php page so that anyone logged in to bidding.php will see a new timer clock when anyone clicks the submit button.
thanks for your help,
Jim Balthrop
It sounds like it would work. The submit button would only have to refresh the page.
JBWebWorks
Thanks Ray.
I know the reload/refresh code should be on the 'clock.php' page.
here is the current load trigger on the 'clock.php' page
pre = (window.onload) ? window.onload : function () {};
window.onload = function () {
pre();
TDisplay.init(61, document.getElementById('countdown'), document.getElementById('notifier'));
I am not sure how to write reload code on the 'clock.php' page that would have the trigger be clicking the submit button on the 'bidding.php' page
Can you help?
thanks,
Jim Balthrop
When you use framework builder they will technically be on the same page... you should be able to call any function directly as if it was on the same page.
JBWebWorks
thanks Ray,
here is the page which is strictly a test page
clock_button.php
It has a static webassist framework with the trigger 'always'
The source page is
clock_auction1.php
the source page has a javascript countdown to a certain datetime
the clock_button page submit button updates the certain datetime plus 60 seconds
the source page has a meta tag auto refresh so that when the recordset with the certain datetime is changed, it starts the countdown.
Is there a way to get the button page to not autorefresh?
Regards,
-Jim Balthrop
Using AJAX instead of a page submit you could prevent the page refresh.
JBWebWorks
Ray,
I have tried to use AJAX and can't seem to get the javascript so show on the page.
Is there a way to get the page that has the javascript function to refresh when clicking the submit button on the page that holds the web assist framework?
Nothing specific to the framework functionality. The WA Framework is server side code which requires a page load to run. AJAX or client side javascript of some sort is the only alternative and won't be effected by the framework builder.
