Warning and fatal errors
Thread begun 10/27/2010 3:11 pm by charlie384232 | Last modified 10/28/2010 1:34 pm by Jason Byrnes | 2182 views | 3 replies |
charlie384232
Hi, I'm using CSS menu writer 2.0.5 and getting the following errors when trying to preview the webpage. The page is a PHP file.
Warning: require_once(CSSMenuWriter/cssmw/menu.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\smartchoice\index2.php on line 65
Fatal error: require_once() [function.require]: Failed opening required 'CSSMenuWriter/cssmw/menu.php' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\smartchoice\index2.php on line 65
Please help!
Charlie
how do you have your site configured?
does the CSSMenuWriter/cssmw/menu.php get created at:
C:\xampp\htdocs\smartchoice\CSSMenuWriter/cssmw/menu.php
it sounds to me like you have the local files setting in your site definition to be created in a different location than the testing server is set.
Try to simplify your site settings.
if the testing server files location is set to:
set the local files file location to the same directory.
charlie384232
Excellent
Jason, you were right on! It was a setting issue with the local root directory.
I change it and everything worked. Thank you for pointing me in the right direction.
excellent, glad to hear it is working.
