Most Popular Product
Thread begun 10/27/2010 2:45 pm by rob294118 | Last modified 11/03/2010 9:07 am by Ray Borduin | 3254 views | 9 replies |
rob294118
Is there a way to manipulate the "Most Popular Product" to a product that you want? Where is this setting?
Thanks.
Dani Chankhour
Yes you can. The most popular is populated using a record set, updating that record set will change what popular product to show.
to make that change browse to webassist/plugins/catalog/
and open the popularbox.php page and update the record set. you will need to make the same change under the basic folder.
rob294118
Where is this folder?
Dani Chankhour
it should be located at the root of the powerstore files.
rob294118
I have PowerStore 3. It is not in the original files.
webassist/plugins/catalog/popularbox.php
I'd suggest making a copy of that file and create your own plugin for the new functionality based on that page. That way if you update to a dot release it won't overwrite your changes and you can easily carry your upates over.
rob294118
I don't understand what you're telling me. The folder does not exist in any release of PowerStore. What am I missing?
The folder, before installation, is in /install/webassist/ , but after you install it gets copied into the root.
I assume you are making updates to a working test site, it should have the /webassist/ directory since you have run the installer.
rob294118
I'm sorry but there is NO webassist directory on my live site or in the original install folder.
That should be populated from a recordset on the index page where the most popular item is displayed.
