Ecart4 errors on remove from shopping cart
Thread begun 10/27/2010 2:19 pm by phil107723 | Last modified 11/02/2010 9:54 am by Jason Byrnes | 5269 views | 8 replies |
phil107723
Hi
I've experienced this problem many times the checkbox to remove an item from the display manager doesn't work and I just take out the remove checkbox from the shopping cart display manager. But this time it worked ... once and now it doesn't. I've removed it several times and replaced it but it isn't working.
// WA eCart Update
if (isset($_POST["eCart1_Update_100"]) || isset($_POST["eCart1_Update_100_x"])) {
$eCart1->UpdateCart();
$Redirect_redirStr="";
if ($Redirect_redirStr != "") {
$eCart1->redirStr = $Redirect_redirStr;
$eCart1->cartAction = "Update";
//WA eCart Check Out Update
if (isset($_POST["eCart1_Checkout_1"]) || isset($_POST["eCart1_Checkout_1_x"])) {
$eCart1->cartAction = "CheckOutUpdate";
?><?php
// WA eCart Continue Shopping
if (isset($_POST["eCart1_Continue_100"]) || isset($_POST["eCart1_Continue_100_x"])) {
if (true && isset($_SESSION['WAEC_ContinueRedirect'])) {
$Redirect_redirStr=siteToPageRel($_SESSION['WAEC_ContinueRedirect']);
$eCart1->cartAction = "Continue";
?><?php
// WA eCart Clear Cart
if (isset($_POST["eCart1_Clear_100"]) || isset($_POST["eCart1_Clear_100_x"])) {
$eCart1->ClearCart();
$eCart1->cartAction = "ClearCart";
?><?php
//WA eCart Redirect Check Out
$Redirect_redirStr="checkout.php";
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
if (strpos($Redirect_redirStr, "?") === false) {
$Redirect_redirStr .= "?".$_SERVER['QUERY_STRING'];
else {
$Redirect_redirStr .= "&".$_SERVER['QUERY_STRING'];
$eCart1->cartAction = "Checkout";
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
And this is the code for the display itself the only thing I have changed is I have manually added some of columns headings because they weren't inserted or in the wrong place.
<div class="eC_Clean_Pacifica_Arial">
//WA eCart Show If Start
if (!$eCart1->IsEmpty()) {
<form action="<?php echo ($_SERVER["PHP_SELF"].(isset($_SERVER["QUERY_STRING"])?"?".htmlentities($_SERVER["QUERY_STRING"]):""));?>" method="post" >
<table class="eC_ShoppingCart" border="0" cellspacing="0" cellpadding="0">
<tr>
<th>Name</th>
<th>Colour</th>
<th>Size</th>
<th class="eC_PriceItem" >Price</th>
<th class="eC_FormItem" >Quantity</th>
<th class="eC_FormItem" >Remove</th>
<th class="eC_PriceItem" >Total</th>
</tr>
while (!$eCart1->EOF()) {
<tr>
<td>
<?php echo $eCart1->DisplayInfo("Name"); ?></td>
<td><?php echo $eCart1->DisplayInfo("Colour"); ?></td>
<td><?php echo $eCart1->DisplayInfo("Size"); ?></td>
<td class="eC_PriceItem" ><?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->DisplayInfo("Price")); ?></td>
<td class="eC_FormItem" ><input type="text" name="eCart1_Quantity_<?php echo $eCart1->DisplayIndex; ?>" size="3" value="<?php echo $eCart1->DisplayInfo("Quantity"); ?>" /></td>
<td class="eC_FormItem" ><input type="checkbox" value="<?php echo $eCart1->DisplayInfo("ID"); ?>" name="eCart1_Delete_<?php echo $eCart1->DisplayIndex; ?>" /></td>
<td class="eC_PriceItem" ><?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->DisplayInfo("TotalPrice")); ?></td>
</tr>
$eCart1->MoveNext();
$eCart1->MoveFirst();
</table>
<div class="eC_OrderSummary">
<table border="0" cellpadding="0" cellspacing="0" class="eC_CartSummary">
//WA eCart Merchandizing Show Start
//ecart="eCart1"
if ($eCart1->GetDiscounts() > 0 || $eCart1->GetCharges() > 0 || $eCart1->GetShipping() > 0 || $eCart1->GetTax() > 0) {
<tr>
<td class="eC_Subtotal eC_SummaryLabel">Sub-total</td>
<td class="eC_Subtotal"><?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->TotalColumn("TotalPrice")); ?></td>
</tr>
//WA eCart Merchandizing Show End
//ecart="eCart1"
//ecart="eCart1"
if ($eCart1->GetDiscounts() > 0) {
//ecart="eCart1"
//ecart="eCart1"
if ($eCart1->GetCharges() > 0) {
//ecart="eCart1"
//ecart="eCart1"
if ($eCart1->GetShipping() > 0) {
<tr>
<td class="eC_SummaryLabel">Shipping</td>
<td>&nbsp;</td>
</tr>
if (!$eCart1->Rules_EOF("Shipping")) {
while (!$eCart1->Rules_EOF("Shipping")) {
if ($eCart1->RuleLooperValue("Shipping") > 0) {
<tr>
<td class="eC_IndividualCharge"><?php echo $eCart1->RuleLooperName("Shipping"); ?></td>
<td><?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->RuleLooperValue("Shipping")); ?></td>
</tr>
$eCart1->Rules_MoveNext("Shipping");
$eCart1->Rules_MoveFirst("Shipping");
//ecart="eCart1"
//ecart="eCart1"
if ($eCart1->GetTax() > 0) {
//ecart="eCart1"
<tr class="eC_SummaryFooter">
<td class="eC_SummaryLabel">Total:</td>
<td><?php echo WA_eCart_DisplayMoney($eCart1, $eCart1->GrandTotal()); ?></td>
</tr>
</table>
</div>
<table class="eC_ButtonWrapper" cellpadding="0" cellspacing="0">
<tr>
<td><input type="submit" name="eCart1_Continue_100" id="eCart1_Continue_100" value="Continue Shopping" />
<input type="submit" name="eCart1_Clear_100" id="eCart1_Clear_100" value="Clear Cart" />
<input type="submit" name="eCart1_Update_100" id="eCart1_Update_100" value="Update" />
<input type="submit" value="Checkout" name="eCart1_Checkout_1">
</td>
</tr>
</table>
</form>
//WA eCart Show If Middle
else {
?><table><tr><td>The cart is empty</td></tr></table>
//WA eCart Show If End
</div>
Phil
Please send a link where I could see the issue and a copy of the cart display page in a zip archive.
phil107723
product.php?pCategory=Clothing&pSubcategory=Men and click a product add to cart .
when i add an item to the cart, I see this error a number of times:
Notice: Use of undefined constant Weight - assumed 'Weight' in C:\HostingSpaces\TRICKSTAR\trickstar.co.nz\wwwroot\sweetstreet\WA_eCart\eCart1_PHP.php on line 88
it is likely that this error is contributing to the issue with removing the item.
Please send a copy of the WA_eCart\eCart1_PHP.php file so i can see why this error is occuring.
phil107723
Sorry that error was caused by something else
Hi Jason
That error was caused by me fiddling with the shipping calculations which you have just helped me with and thanks to you will have resolved shortly.
Phil
when i view source of the cart page, the delete checkbox does not have a value:
<td class="eC_FormItem" ><input type="checkbox" value="" name="eCart1_Delete_0" /></td>
it should be getting a value from the cart ID column:
double check in the add to cart buttons that you are giving the ID cart column a value.
phil107723
Thanks again
Thanks a lot . I'll have a look.
phil107723
It Worked
For the ID wasn't being added to the add to cart information so I added it myself and it is working perfectly. Many thanks
Ok, glad to hear it is working.
