Sticky: Known Issue (and solution) for Framework Builder: PHP memory allocation error
Thread begun 10/27/2010 2:50 am by John Langer | Last modified 10/28/2010 6:50 am by Jason Byrnes | 1181 views | 3 replies |
John LangerBeta Tester
Just a pointer: The instructions do not give Windows 7 specifics. No problem to me but others may find it confusing (perhaps).
Windows 7 and Vista are the same path, I will keep in mind for the future to mention that in the Known Issues though, thanks for the heads up.
Yes I'm aware of that, my concern was that those less experienced may not realise that and end up asking support, therefore using up your time. It only needs the words "and Windows 7" to be added to the doc after "Windows Vista".
Anyway, enough said. :)
Thank you for the suggestion, I will keep it in mind in the future when writing the known issues.
