Known Issue (and solution) for Framework Builder: PHP memory allocation errors
Thread begun 10/26/2010 12:35 pm by Anna Robinson | Last modified 4/25/2011 7:36 am by Steve | 6699 views | 5 replies |
Anna Robinson
Some Framework Builder users have experienced PHP memory allocation errors when creating or applying a theme. We have a simple fix for this bug, just a matter of copy/pasting a file. Log in and visit the Download Center. Click on Framework Builder; then click on the Known Issues section. Download the zip file and follow the instructions in the readme file.
toms016390756
Thanks Anna
DarylBeta Tester
I have updated the two files as per the instructions.
Do I now need to create the template again?
No, just replace the files in your site and it should function properly.
Steve
Not working
Hello,
I am fairly informed of this problem as I was the one that initially brought it up. It's related to the theme path improperly targeting the new file name rather than the selected themes name.
I reformatted my computer of the weekend and sure enough I have this problem again. I have replaced the two files and also deleted the dat file.
Any ideas on how this fix is not doing as expected?
Steve
**** solved ****
The provided update files are in complete and need this file:
WAFW_CreateThemePage.js
to fix the problem.
There is an older post where this file was provided by a WA Tech. I downloaded it and problem resolved. So three files total are needed at this time not just the two linked from the Support area.
Here is a link to the needed files:
showpost.php?p=80070&postcount=25
