Blank Screen when Installing PS3
Thread begun 10/26/2010 12:33 pm by mrobben375515 | Last modified 10/28/2010 1:18 pm by Jason Byrnes | 3010 views | 5 replies |
mrobben375515
When I enter the database credentials and select next the page loads for a while and then goes to a white screen. I could have one of the credentials wrong, but I have no idea which one. I inserted the following code to show errors in the top of the page because I saw it on another thread for power galery installation.
error_reporting(E_ALL);
But nothing showed up after that either. It's on install page 2.php and I'm running PHP 5.2.12
what version of MySQL?
can you create a new php page and add this code to it:
<?php phpinfo(); ?>
then send us a link so we can look at the php settings.
mrobben375515
php_info.php
It looks like your host is using MySQL version 4.1.14
Client API version 4.1.14
This will need to be upgraded to MySQL 5.
mrobben375515
Ok, I upgraded to php5 a few days ago before I submitted this post, because it wasn't letting me get past the first step where it checks if php5 is installed. After I made the change to php5 it let me get by step 1 and verified that I was using php5. Is this a different setting I need to change now, because when I'm on step 1 it says "PHP 5.2.12, PHP 5.2.12 is installed."
Yes, this is the MySQL Server version, not the PHP version.
