Warning: mysql_select_db(): supplied argument is not a valid
Thread begun 10/26/2010 10:43 am by gpaul | Last modified 10/27/2010 10:29 am by gpaul | 1624 views | 2 replies |
gpaul
Full error
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/a/l/i/alinde52/html/confirm.php on line 162
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/a/l/i/alinde52/html/confirm.php on line 196
I have read through other posts with the same problem, that the DB connection to the local v remote is not listed correctly, however I am not finding this to be the case.
I have a local and remote connection file, and I searched and changed any that were pointing to the local, however I am still getting the error.
Where should I look next?
Thank you
gary
gpaul
Sorry...
I'm sorry, that really was pretty stupid of me...
Lines 162
Line 196
$WA_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
Thank you
Gary
gpaul
Solved
For future reference if someone else runs into this problem, it seems that WA, for some reason, did not insert into the confirm.php page a connection to the database.
I added this to the top of the page...
<?php require_once('Connections/jfin.php'); ?>
Gary
