some files upload some don't
Thread begun 10/26/2010 6:47 am by wbrooks199805 | Last modified 11/30/2010 10:20 am by Jason Byrnes | 8088 views | 24 replies |
wbrooks199805
I have a client that has people upload their image. So I have the users insert goes to database most of the time but sometimes the image shows up in the folder but not in the database. How is that possible? I have tested it on my end and so has the client without any issues.
These are the original files. I have now removed the update button and adding a progress bar.
You have the image file name coming from the last name form element.
The only way i can see this happening is if the last name where left blank.
Perhaps add validation to the last name form element to ensure that it is not left blank.
wbrooks199805
Here are the files I am using now..
I Have MANY people that are not able to upload their images. Some upload and some don't. I am having major problems with my client and need an answer.
All of these people are putting in there last names and it has validation. That is definitely not the problem. Btw, some images are not uploading to the folder. I test it and it works.
Could it be a time out problem and if so how can I fix that?
It could be that the images that are not uploading are to large.
You may need to edit the php.ini file to allow for large file uploads.
See the following page for details on php settings that effect large file uploads:
wap_upload.asp?page=php2
wbrooks199805
Will try it..
I am on godaddy and see if they can help me out with it.
most of those settings can be changed on the page itself using ini_set(). for example:
<?php ini_set('memory_limit','256M');
wbrooks199805
used this on ini file
max_input_time = 500
max_execution_time = 500
post_max_size = 256M
upload_max_filesize = 256M
Did that get it working for you?
wbrooks199805
Not sure yet.
Waiting on some more people to upload. Let you know.
ok, thanks.
