Error with contact form
Thread began 6/15/2009 3:45 pm by andres13156 | Last modified 6/24/2009 9:08 am by andres13156 | 2557 views | 4 replies |
andres13156
I received this error if I combine PowerCMS with WAUE when i tried to send the contact form
Warning: Cannot modify header information - headers already sent by (output started at D:\inetpub\vhosts\finautos.com.mx\httpdocs\traslados_al_aeropuerto.php:10) in D:\inetpub\vhosts\finautos.com.mx\httpdocs\traslados_al_aeropuerto.php on line 20
What is on line 10 and what is on line 20 of the page mentioned in the error. It may be something as simple as a blank line or space character on line 10 causing the issue. The solution is most likely to fix the problem on line 10 so that the error never occurs on line 20.
andres13156
line 8 to 23
<?php include "Connections/localhost.php"; ?>
<?php include "WA_CMS/WA_CMS.php"; ?>
<?php require_once("WA_Universal_Email/PEAR_Mail_using_SMTP_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="PEAR Mail using SMTP"
//Send Loop Once Per Entry
$RecipientEmail = "contacto@finautos.com.mx";include("WA_Universal_Email/WAUE_traslados_al_aeropuerto_1.php");
//Send Mail All Entries
if ("gracias_por_reservar.php"!="") {
header("Location: gracias_por_reservar.php");
If I removed 8 and 9 works without a problem.
OK. then the problem is the space at the end of:
on line 9... delete the space that appears at the end of that line and the error will go away.
andres13156
OK, the error was from copy/paste from CMS code generated. Now is working thankyou!
