Unterminated string constant
Thread begun 10/25/2010 12:53 pm by mike174890 | Last modified 10/26/2010 8:07 am by Jason Byrnes | 11779 views | 6 replies |
mike174890
Here is the script that DataAssist built in Dreamweaver CS4
<%@LANGUAGE="JAVASCRIPT" CODEPAGE="1252"%><!--#include file="../WA_DataAssist/WA_AppBuilder_VB.asp" -->
<!--#include file="../Connections/MainGrantHome.asp" -->
Can you tell me what to fix? Unterminated string constant Error says Line 2, line 2 starts <!--#include file="../Con
that line would not cause that error.
can you copy and paste the exact error text you are getting.
mike174890
copy of error
Microsoft JScript compilation error '800a03f7'
D:\HOSTING\LOANS2FUND\MONEY\../WA_DataAssist/WA_AppBuilder_VB.asp, line 2
mike174890
web page
Grant_Finder.asp
you have VBScript on the page,
but this line is telling it to use the Javascript Processing engine:
change that to:
<%@LANGUAGE="VBScript" CODEPAGE="1252"%>
mike174890
new error message after changing to VB
New Error Message:
Microsoft VBScript compilation error '800a0401'
Expected end of statement
/money/Grant_Finder.asp, line 4
var Recordset1_cmd = Server.CreateObject ("ADODB.Command");
Current Script:
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%><!--#include file="../WA_DataAssist/WA_AppBuilder_VB.asp" -->
Recordset1_cmd.ActiveConnection = MM_MainGrantHome_STRING;
Recordset1_cmd.CommandText = "SELECT * FROM FWGM";
Recordset1_cmd.Prepared = true;
var Recordset1 = Recordset1_cmd.Execute();
var Recordset1_numRows = 0;
When establising site I received a message "Please edit the 'WADAFWGM' recordset and set the type for 'ParamID'"
I added record set to each dataassit page
You have a mix of ASP VBSript and ASP Javascript on this page. You cannot have both.
In you site definition, what is the Server language set as?
Chose one or the other and stick with that to eliminate these errors.
