PowerStore 4 Galleries Error
Thread begun 10/24/2010 5:42 am by Jason Kline | Last modified 11/05/2010 1:33 pm by Jason Kline | 4546 views | 11 replies |
Jason Kline
I'm getting this error when I try to preview Galleries.
Warning: Invalid argument supplied for foreach() in /home/xxxxxxxxxx/public_html/galleries/global.php on line 79
in the galleries/global.php file, can you change line 79:
foreach($sxe->channel->item as $item) {
die("<pre>".var_dump($sxe)."</pre>");
and post back the results please.
Jason Kline
I have attached the results.
OK, thanks, that helps.
you can revert that back, one other change to make for troubleshooting.
change line 44:
function get_gallery($url) {
die($url);
and post the results from that.
Jason Kline
Here you go. see attached
Ok, you can revert that change, that helped me see what tyhe error is.
it looks like you have automatic forwarding of HTP to HTTPS that is causing the issue.
try changing the line:
$Root_URL = ((isset($_SERVER['SERVER_PROTOCOL']) && strpos($_SERVER['SERVER_PROTOCOL'], 'HTTPS') !== false) ? 'https://' : 'http://') . $_SERVER['SERVER_NAME'] . ( (isset($_SERVER['SERVER_PORT'])&& $_SERVER['SERVER_PORT'] != 80)?":".$_SERVER['SERVER_PORT']:"") . $assumedRoot;
$Root_URL = "https://klineitsolutions.com/";
Jason Kline
After changing that code I am getting the following. See attached screenshot. Notice the URL at the bottom.
Jason Kline
Do I need to add this code to other global.php files to force http to https to work across the entire PowerStore?
Jason Kline
Hi Jason,
I am checking to see if you had any more ideas on this issue.
Jason
