Dataassist Search works locally, but fails on web server
Thread begun 10/23/2010 7:27 pm by eaefaw380137 | Last modified 10/27/2010 7:00 am by Jason Byrnes | 3160 views | 6 replies |
eaefaw380137
Fatal error: Call to undefined function setquerybuildersource() in C:\hshome\user\mydomain.com\search-results.php on line 81
I get this error when I try to run the search pages on the web server. Everything runs perfectly on my local php server.
I have added the search option into the template portion of my site "templatename.dwt.php"
Any ideas would certainly be appreciated.
CraigRBeta Tester
your error message is basically saying that the function is not found on your server using the path specified, so it is either absent, (hasn't been uploaded) or is on a different path.
make sure that the WADbSearch folder has been uploaded to the server.
eaefaw380137
Thanks for your responses and suggestions. I was able to clear the error that I was initiallly getting by rearranging some of the PHP code. However, now my search returns all of the records on the web server, but works correctly on my localhost. I uploaded all of the necessary files/folders but my search still returns the entire product line and not the items with the search words.
please provide a link and compress the search and results pages into a zip archive so i can look at the code.
eaefaw380137
Jason,
You are the best and always willing to offer your support. I really appreciate your efforts and hope that WA is compensating you handsomely. With that said, it looks as if at this time, the search option is working correctly. As I mentioned earlier, I did upload all the necessary files/folders, but it must have taken some time for them to post to the server. I checked prior to sending you the link/files and it is now working. I am hoping it is a delayed server issue and hopefully not my code. If I experience the problem again I will post again to this thread. Again, many thanks!
Excellent, glad to hear it is working.
