eCart 5 SagePay PROTX URL error (bad gateway)
Thread begun 10/23/2010 8:05 am by chris382476 | Last modified 10/23/2010 8:05 am by chris382476 | 1048 views | 0 replies |
chris382476
Hi All,
I thought I would let you know of a bug I discovered with eCart 5 when using SagePay.
PROTEX was bought bought (several years ago) by SagePay but for some reason, the eCart checkout wizard hasn't got the new URLs of their payment pages in it and you will get an error when trying to checkout.
Simply change the following line in confirm.php
<form name="checkout_Protx_VSPForm" action="https://ukvpstest.protx.com/VSPSimulator/VSPFormGateway.asp" method="post">
to...
<form name="checkout_Protx_VSPForm" action="https://test.sagepay.com/Simulator/VSPFormGateway.asp" method="post">
and all will work :-)
I was also advised by support when I told them about this that I can update an XML file on my local system which will stop this problem happening when apply a checkout...
in the mean time you can change the URL that will be used for the VSP Form action by editing the following file:
Configuration/Shared/WebAssist/eCart/Checkout/Remote/postXML/Protx_VSPForm
.xml
If you need help locating the Users configuration folder, see the Common Installation issues PDF:
you will need to change the URL in this tag:
<wa_checkout_action
url="https://ukvpstest.protx.com/VSPSimulator/VSPFormGateway.asp" />
to the URL you wish to post to.
