database error
Thread begun 10/22/2010 2:49 pm by i.edwards384429 | Last modified 10/26/2010 9:30 am by Jason Byrnes | 3432 views | 6 replies |
i.edwards384429
database error
Hi
tested my site locally works perfectly with the search (ok needs tweeking) and the permissions.
Uploaded it to the love server made sure the connections files was correct and tried it. o matter what I try I get the following error
No database selected
Any ideas?
a live page is
boats_users_Registration.php
thanks
Ian
anonymous
Ian,
Could you attach the code from your page here. Without seeing the code, it is tough to tell where the problem is originating.
Best regards,
Brian
i.edwards384429
update
Hi
sorry, silly me. End of a long day and having got it working on my test server was a bit shall we say upset ;-(
I've attached all the site files except the images and template files because I'm not at all sure where my error os==is
I've had a look this morning and just cant see why there is no database connection on any of the pages .
I have tested the connection and it is viable.
thanks
Ian
the no database selected error means that there is a problem with the database connection file. It usually happens if the table being selected in the SQL SELECT statement doesnt exist on the server.
it can also happen if the database being used in the connection file does not exist on the remote MySQL server.
it sounds to me like the DB on the remote server does not have the same set of tables as the DB on the local server.
i.edwards384429
update
Hi Jason
I dumped the sql for the two tables on my local server and deleted the tables on the remote.
I then ran the sql to put the tables inot the remote database.
I now get the error
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/fhlinux010/y/yachtsandboatsforsale.co.uk/user/htdocs/WA_SecurityAssist/Helper_PHP.php on line 14
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/fhlinux010/y/yachtsandboatsforsale.co.uk/user/htdocs/WA_SecurityAssist/Helper_PHP.php on line 20
looking at these lines sound like there is a problem with $WA_Auth_Parameter["connection"])
What does this line mean?
thanks
Ian
i.edwards384429
update
Hi
problem solved somehow something was corrupt. I used the powercms to create a new connection file and used that instead of my exisiting one.
All works oK
weird
thanks for the assist
Ian
excellent, glad to hear it is working.
