Universal Email form linking
Thread begun 10/22/2010 10:43 am by ko400283 | Last modified 10/25/2010 10:30 am by Jason Byrnes | 5200 views | 14 replies |
ko400283
New to Universal Email, I followed the setup, not sure how this is supposed to work, how does the generated php code link to the form on my page? Uploaded files, fill out my form and hit submit and does nothing. any help much appreciated!
Thanks,
Kenn
If you selected the option to Use one of the Presets and to Create an File for the email, there will be code in the template file to loop through each form element to include it in the email message.
Did you also set it to go to another page after the email is sent?
if you set a redirect page, clicking the submit button on the form should redirect there after the email is sent.
If the email is not being delivered, you will need to double check your settings.
make sure to enter the correct SMTP server.
make sure to set a valid From Address for your domain.
emake sure the to address is not the same.
on the SMTP server settings tab, you may need to check the option to Include the From address as an extra parameter.
If you are still having any luck, please compress your file and the webassist/email folder into a zip archive.
Also are you testing locally or remotely?
and who is your host?
ko400283
Hi Jason,
doh , I didn't setup the smtp, all that info. Let me try that! thank you for replying!
Kenn
No worries.
ko400283
Hmm, still not working after adding smtp info, I use westhost for hosting. testing on live site also. attaching my files
Your button is not a submit button:
<input type="button" value="Submit" name="" class="btn" />
this will not submit the form. you need to change the type to submit:
<input type="submit" value="Submit" name="" class="btn" />
ko400283
ah, ok, thank you!! will try, thank you for replaying so fast also!
Kenn
ko400283
universal email form
Hi Jason,
seems the form submits not but no redirect to the thank you page , it refreshes the page though. and no email come into inbox, attaching all the files again, thanks for any help!!!
Kenn
I dont see a form on the index page you sent?
try changing the Universal Email trigger from Currant page submit to any form post.
ko400283
ok attached, which file do i find the "Universal Email trigger from Currant page submit to any form post. " Also which file does the smtp info show up in?
Thanks again!
Kenn
