PS3 Advanced Options Problem - Product Details Not Displaying
Thread begun 10/22/2010 7:58 am by Adam Zahler | Last modified 10/27/2010 3:10 am by Adam Zahler | 3302 views | 6 replies |
Adam Zahler
I seem to be having problems with adding advanced options to products. Please check Baron-Fire-Safe-with-Electric-Lock and you will see a safe that has 4 different model variations for the same series. The default model displays fine but as soon as you choose a different model from the dropdown details are not displayed - no image, no product title, price changes to '$.00', description dissappears and so on. Even if I then try to choose the first model again, details are not shown.
I've tried playing around with various options and I must be missing something very obvious.
I have had someone modify the files below for URL re-writes so I'm not sure if this is the problem...
/CSSMenuWriter/cssmw_home/menu.php
/.htaccess
/index.php
/Products_Detail.php
/Products_Results.php
If any of the above have caused the issue I'm guessing it would be the Products_Detail.php
Please help because I was very excited earlier today when I found out the URL re-writes are working very well - I'm an SEO person by trade.
Thanks,
Adam
mick106153
Go to your admin, select the product in question, choose "update".
In there you will notice that at various places is a checkbox that reads "update all options".
The very first of these, next to the "Available online" checkbox if selected will cause every iteration of that product to have and display the same options. Probably not what you want.
Go through the list and select the "update all options" checkboxes that are exactly the same for every iteration of that product and "update" at the bottom of the page.
Than, and this is the boring part, after the product updates check to see that the changes have taken hold, if so, select "update" again and if, as an example, size is the first option choose the NEXT size in the option drop-down and wait for a refresh and choose all the various necessary changes on down as well as making any text or graphic changes and hit "update" at the bottom of the page.
You'll need to do that for each different iteration of that product.
Some of these changes might be more easily done directly in the database.
I had to change a table in a long description and because each long description was potentially a little different from every other it was easier and much quicker to do it in the database.
I hope this is the answer you need.
Mick
Adam Zahler
Thanks for the feedback Mick. I just tried what you suggested and it doesn't seem to make any difference I'm afraid. Even tried checking all the update all options boxes as well. Any other ideas?
Adam
mick106153
As a test…
Try creating a new product with one option - size (small and large) and select all the "update all options" check boxes for the areas that will remain the same in all products and save that.
Than find the product in Admin and choose update.
Assuming for the moment that the only differences will be size, price and SKU - choose the next size option from the drop down and after it refreshes, change the SKU and the price and choose "update" at the bottom of the page and see what the results are.
Let us know
Mick
Adam Zahler
Hi Mick,
It turned out there was a small issue with the modification my guy made but it's all fixed now. Thanks for your suggestions anyway and your time!
Adam
mick106153
Adam please!
What was the issue exactly?
Mick
Adam Zahler
Hi Mick, unforunately I'm not a coder so I couldn't tell you what the issue was. I simply had my guy check it and he said he had missed something which he corrected - so it was to do with his modification only and not the original PowerStore 3 coding that WebAssist did. No one else should have this problem as it would not have occured without our mods.
Adam
