template error??
Thread begun 10/22/2010 5:42 am by i.edwards384429 | Last modified 10/25/2010 7:13 am by Jason Byrnes | 1999 views | 3 replies |
i.edwards384429
template error??
Hi
This is what I've done. Created a search based on a Dataassist wizard.
I then added a table called boat_users. Fields name, surnmae, email,password etc.
I then opened Index.php
followed the steps stage by stage in the "getting started with security assist"
stage 1 selected my template and my editable region called Main_Content and the table
stage 2 selected modulular
stage 3 selected the fields for the user and set the unique column to email and the redirect to duplicate.php
stage 4 set update fields
stage 5 set log in to useremail and password, ticked both remember me and automatic login, set if login sucessfull to go to my seach page created using databassist.
stage 6 email to user email, selected mail for linux and deleted the server name and return path.
selected finish
then the usual screen activity until I get the error:
Making this change would require changing code that is locked by a template ora translator. The change will be dicarded.
It seems that boat_users_login has focus.
clicking Ok elicits a repeat message eight times (with the proverbial beep noises) until the wizard eds and the rules wizard opens.
Any ideas what the issue is?
I uploaded the files created by the wizard and the template file.
thanks
Ian
The error you are getting is a common one when working with templates in Dreamweaver.
There is no solid fix for the issue, but I have discovered a workaround. See the following thread for details:
showthread.php?t=4509
i.edwards384429
update
Hi Jason
like the work around, worked a treat on to the next issue .....
thanks
Ian
You're welcome.
