Accessing Downloadable Documentation
Thread begun 10/21/2010 6:22 pm by neilo | Last modified 10/21/2010 6:22 pm by neilo | 1057 views | 0 replies |
neilo
Hiya,
I like to have a local copy of the pdf support files for the extensions I own.
I frequently have problems being able to access an easily downloadable version of those pdf documents. I often have to use Acrobat Distiller and use the print function to print the php page to a pdf document.
The problem is that the link to a downloadable pdf on some of the pages just links to an xml file.
For Example, two out of the first three I tried in the support resources documentation for eCart do this.
Try going to 'Debugging eCart Transaction Failure issues' (Here) and pressing (or trying to 'save as') the small 'Print' pdf icon near the top of the page on the right.
It would also be brilliant if you used a select-and-zip or download all facility (you could buy it from DMX Zone here!) so we wouldn't have to go through the tedious task of doing them individually.
Please could someone post back when the PDF links have been fixed, so I can download all the support resources,
Cheers.
