Can I load an image dynamically via the bindings
Thread begun 10/21/2010 4:54 pm by elewis93815 | Last modified 10/22/2010 1:59 pm by elewis93815 | 1885 views | 2 replies |
elewis93815
I'm building a products page via eCart and can't figure out how to load the product images dynamically. I have created the record set and have inserted the image bindings: Image, description, price and item name. All of my text loads dynamically, the image is the only element that does not show the picture it shows the text (image file name i.e. red_cupcake.jpg).
Please advise.
Erick
CraigRBeta Tester
on line 168 of cupcakes.php you want to replace
<?php echo $row_rsCupcakes['IMAGE']; ?>
with
<img src="<?php echo $row_rsCupcakes['IMAGE']; ?>" alt="some alt text" />
you can do this via Insert->Image, and choose to select file name from data sources, where you add the field with the path to your image.
Ensure your alt text is meaningful, (it helps seo) and if your images are all in a folder, (such as images), then you may need to add the folder path to the beginning of the source string
elewis93815
That fixed it Thanks!!!!!
Erick
