Show/Hide based on Time
Thread begun 10/21/2010 3:16 pm by fdotmedia | Last modified 10/25/2010 7:19 am by Jason Byrnes | 2423 views | 5 replies |
fdotmedia
I have a registration page and I need to hide "classes" based on whether or not the client is within the 48 hour window...
Example: 10/22/2010 is a class, the last day to register for this class is 10/20/2010 - otherwise they get a grayed out or non-selectable, even invisible, option...
I wrote this as a "timebomb" for a different project because I'm not sure webassist does anything like this...
$startdate = $row_product['startdate'];
$enddate = $row_product['enddate'];
$todays_date = date("Y-m-d");
if ($enddate <= $todays_date) {
header('Location: expired.php');
else{
if ($startdate > $todays_date){
header('Location: notyet.php');
else {
Obviously, the header location won't work I need to call a function that "hides" the option...
This is how I'm showing the dynamic dropdown. From the ClassDetails DB...
do {
<option value="<?php echo $row_ClassDetails['CDID']; ?>" ><?php echo $row_ClassDetails['CDDate']; ?> <?php echo $row_ClassDetails['CDName']; ?></option>
} while ($row_ClassDetails = mysql_fetch_assoc($ClassDetails));
I have a db that has a StartDate and LastTimeDate to handle the calculation...
Any help would be greatly appreciated...
Ted
yopu would need to put an if statement around the select list to determine if ot should be shown
you say you have LastTimeDate column that has the last day to show the event? the something like this should do it
do {
if($row_ClassDetails['LastTimeDate'] >= date("Y-m-d")) { ?>
              <?php ?><?php
} while ($row_ClassDetails mysql_fetch_assoc($ClassDetails));
fdotmedia
Perfect Jason... But I went about it a tad differently...
I wrote this in the recordset above the <html>
SELECT * FROM ClassDetails WHERE NOW() < `CDLastTime`
Therefore I'm only returning the classes that are available...
The problem I'm having now is formatting the output as m/d/Y... Currently I'm using the DATE as the structure of the Row - and it returns yyyy-mm-dd which the manager of the project doesn't want...
When I use the mySQL function DATE_FORMAT() I get the perfect results, but, it removes my additional dynamic rows...
SELECT DATE_FORMAT( CDDate, '%m/%d/%Y' ) AS formatted_date FROM ClassDetails
So... Do I need to add a temp table to output the date to? If I duplicate the recordset and put the DATE_FORMAT() SQL code in it ABOVE the current RS it returns nothing, BELOW it returns the day only...
I've tried pimping the echo $row_ClassDetails['CDDate'] in the loop and have gotten 12/31/1969 returned over how many records there are or nothing...
do {
I know I'm doing something wrong, I just can't figure it out...
Would it be best to add the DATE_FORMAT() to a recordset above the <html> or write out the php???
I'm lost...
fdotmedia
btw... dumest thing ever...
$timestamp = $row_ClassDetails['CDDate'];
$date = date("m/d/Y",$timestamp);
echo $date;
spits out 12/31/1969
I'm so frustrated!
fdotmedia
Here's how I fixed it...
$mysqldate = $row_ClassDetails['CDDate'];
$mydate = date("M, d Y",strtotime($mysqldate));
echo $mydate;
Thanks for letting me interrupt your day with tiny bits of easiness...
OK, glad to her you fixed it.
