Upload into recordset
Thread begun 10/20/2010 4:50 pm by ddileo415479 | Last modified 10/21/2010 7:06 am by Jason Byrnes | 1136 views | 1 replies |
ddileo415479
If I want to grab the new server name for an image and insert it into a database, should this be bound to a hidden form? If so, would you use create a new Server Variable from bindings, or would you use the bindings in Upload Files > Server File Name?
Also will this work using multiple upload functions on the same page?
Code In Page:
<td>*Image 1:</td>
<td><input name="Image1Path" type="file" id="Image1Path" size="60" />
<input name="hiddenField" type="hidden" id="hiddenField" value="<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverSimpleFileName"]; ?>" /></td>
</tr>
<tr>
<td>Image 2:</td>
<td><input name="Image2Path" type="file" id="Image2Path" size="60" /></td>
</tr>
<tr>
<td>Image 3:</td>
<td><input name="Image3Path" type="file" id="Image3Path" size="60" /></td>
</tr>
Insert Function:
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
$insertSQL = sprintf("INSERT INTO tb_nominate_bus (Category, ContactName, Title, Company, Address1, Address2, City, `State`, ZipCode, Country, EmailAddress, Phone, Fax, Installer, Operator, Image1Path, `Description`) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['Category'], "text"),
GetSQLValueString($_POST['ContactName'], "text"),
GetSQLValueString($_POST['Title'], "text"),
GetSQLValueString($_POST['Company'], "text"),
GetSQLValueString($_POST['Address1'], "text"),
GetSQLValueString($_POST['Address2'], "text"),
GetSQLValueString($_POST['City'], "text"),
GetSQLValueString($_POST['State'], "text"),
GetSQLValueString($_POST['ZipCode'], "text"),
GetSQLValueString($_POST['Country'], "text"),
GetSQLValueString($_POST['EmailAddress'], "text"),
GetSQLValueString($_POST['Phone'], "text"),
GetSQLValueString($_POST['Fax'], "text"),
GetSQLValueString($_POST['Installer'], "text"),
GetSQLValueString($_POST['Operator'], "text"),
GetSQLValueString($_POST['hiddenField'], "text"),
GetSQLValueString($_POST['Description'], "text"));
Due to limitations of the Dreamweaver Insert Record Server Behavior, the uplaoded file name can not be retuned at insert time.
to accomplish this, you will need to use the DataAssist insert record server behavior instead:
dataassist/
The problem is that the Dreamweavver insert record behavior will only allow you to get information from form elements.
The server file name is not created until the file is uploaded to the server. The server file name is only available at run time and cannot be assigned to form since it is created after the form submits.
The DataAssist insert record behavior will allow yo to get information from any server variable listed in the bindings panel, including the Upload Files -> Server File Name
