users.sql database table not importing
Thread begun 10/19/2010 1:09 pm by pat356751 | Last modified 11/04/2010 6:38 am by Jason Byrnes | 7784 views | 29 replies |
pat356751
I'm having problems importing the users.sql database table using mysql query browser and PHPMYADMIN. I ran the sql script from terminal with the following results. This may not mean much but I'm looking for a way to troubleshoot the problem.
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'databases' at line 3
mysql> CREATE TABLE `users` (
-> `UserID` int(11) NOT NULL auto_increment,
-> `UserEmail` varchar(500) default NULL,
-> `UserPassword` varchar(500) default NULL,
-> `UserFirstName` varchar(50) default NULL,
-> `UserLastName` varchar(50) default NULL,
-> `UserCity` varchar(90) default NULL,
-> `UserState` varchar(20) default NULL,
-> `UserZip` varchar(12) default NULL,
-> `UserEmailVerified` tinyint(1) default '0',
-> `UserRegistrationDate` timestamp NULL default CURRENT_TIMESTAMP,
-> `UserVerificationCode` varchar(20) default NULL,
-> `UserIP` varchar(50) default NULL,
-> `UserPhone` varchar(20) default NULL,
-> `UserFax` varchar(20) default NULL,
-> `UserCountry` varchar(20) default NULL,
-> `UserAddress` varchar(100) default NULL,
-> `UserAddress2` varchar(50) default NULL,
-> PRIMARY KEY (`UserID`)
Do not use the teerminal for importing the database, you should be using PHPMyAdmin for this.
see the "How to import a MySQL (.SQL) file to your database" tutorial on the learning resources page foir details:
resources.php
pat356751
I did and it didn't work.
Did PHPMyAdmin give an error to?
what did happen?
what version of MySQL are you using?
pat356751
version 5.1.51
what did happen?
pat356751
error #1046 - No database selected
did you select a database in the list of databases in PHPMyAdmin before going to the SQL tab and executing the SQL statement?
pat356751
"did you select a database in the list of databases in PHPMyAdmin before going to the SQL tab and executing the SQL statement?"
No, I didn't. I selected test and the sql data is part of the test database. But I presume that isn't what is needed. I then went to MySQL localhost and created a new database called users. Next I selected the SQL tab and copied the users.sql table into the "Run SQL query/queries on server "localhost":" field and selected GO. users now shows up as a database. Is this the correct procedure?
Yes, that is the correct procedure, you need to select the database that the users table will be created in before running the script.
