serial code for css menu writer
Thread begun 10/18/2010 4:48 pm by chris400661 | Last modified 10/21/2010 3:37 pm by CraigR | 2512 views | 3 replies |
chris400661
When trying to activate css menu writer in dreamweaver cs3 I get the following error:
Uneexpected error: -2.
activation cannot be comleted. Visit the WebAssist Community Forums for assistance.
Please advise. My subscription has run out but I never installed it so I should be entitled to install it still correct?
CraigRBeta Tester
If your subscription has run out then you are no longer able to use any subscription product.
If you purchased the product before or since subscription, then you will have a licence to run it, but the serial number will be different from the subscription serial number, so you will need to reactivate it.
chris400661
Activation issue
So when you say reactivate it do you mean buy it again? Because if I bought the software I should be able to use that version without having to purchase it again. Please advise.
Thanks,
Chris
CraigRBeta Tester
if you had a subscription, you did not buy the extension, you were entitled to use it, (and all of the other extensions) for the duration of the subscription.
if you purchased the extension, then its yours, to keep, forever.
if however you were using the extension as part of the subscription, and you owned it beforehand, you may well be using a different activation serial number.
if this is the case, log in to your account and check your purchase history, and your serial number details will be there.
