Line 60 Error
Thread begun 10/18/2010 3:50 pm by esms | Last modified 10/24/2010 8:56 am by anonymous | 4982 views | 10 replies |
esmsBeta Tester
Line 60 Error
Hello,
Just updating my site and thought I'd use this extension. Had it for ages but not used it yet.
However, after creating a simple contact form, I receive the following error:
Contact.php
Is there something I need to add to line 60?
can you send a copy of your page so i can see the code producing the error.
esmsBeta Tester
Hello Jason,
I've zipped the contact.php file and attached. Is this ok - I couldn't see another method of attaching a php file.
esmsBeta Tester
Anyone know the reason why I get a 'Line 60' error? Not sure what it means other than nothing shows up in IE8 other than an error message.
The problem is the Validation Show If Behaviors.
You should be able to fix the issue by double clicking each one and reelecting the validation failure to trigger that show if region.
esmsBeta Tester
Sorry Jason, I didn't understand a word of that.
I notice Form Builder 2 is out. Might have to give that a try instead.
anonymous
Originally Said By: esms
If you look in the Server Behaviors Panel, you will see a list of server behaviors... some of which will be your validations. You can click each validation "show if" behavior to not only reveal the details but also change or edit the trigger for the show if. You need to change the trigger to be set to the correct failure.
Best regards,
Brian
esmsBeta Tester
Hello,
Version 1 didn't seem to work so I've bought and installed version 2 instead and created a new form.
All seems OK but I can't seem to find a setting that allows me to 'GoTo' a page once the form has been submitted. Does this have to be done manually?
Cheers
anonymous
When you open CSS Form Builder, there is an input near the bottom of the dialog box that says "Specify Action Page." It defaults to self because that is typically the preferred method for processing. Then after processing, you could redirect somewhere else if you wanted to.
Best regards,
Brian
esmsBeta Tester
So, if I change this 'Specify Action Page' to another page (a Thank You page for example) then will this still load the original contact form page?
